Blackheads
1 finger either side + apply pressure. I've been doing that when ever they come for the last 10 years and not got a scar. For ones on your chest and back - I saw street doctor and they said most often they are a bit tougher to get rid of and you can get some stuff from your doctor that breaks them down. Shouldn't try and pop those!
They come out easy. :P just to many to pop haha.
Well, i have a lot of blackheads, i used to have a face full of spots, but not it's just blackheads on my nose, and a lot of them, all the off the self stuff don't work, and niether does some precreption stuff i had for my spots.
Anyone got and hits or tips for removing black heads?
Regards
Ben
it's the type of skin you have..oily
i believe a prolonged sun tan will make them go away. the heat will open the pores and the tanning should remove the top layers of skin. the uv light may kill bateria too.
There used to be some of this blue gel stuff from cleracel or w/e its called, and it did the job perfectly, they dont make it anymore for some reason, I loved it, I put it on my face and just left it, it did burn and sting pretty bad but the end results where a really clean face!, the sting was painful but I just took that as the sign it was working :cool:
