- 29 Sep 2003
- Newcastle upon Tyne
I'm in Newcastle and can't wait for them to turn on the upgrade.
It's already on (at least for me in Heaton).
mrochester said:It's already on (at least for me in Heaton).
gazza1972 said:Besides faster DL from NG's, what other benefits will there be for average surfer/surferette by having a shiny new 10meg connection.
From what i've been lead to believe most sites won't support 10meg speeds anyway.
Faster downloads for multiple files, and file downloads not saturating your connectiongazza1972 said:Besides faster DL from NG's, what other benefits will there be for average surfer/surferette by having a shiny new 10meg connection.
From what i've been lead to believe most sites won't support 10meg speeds anyway. It will be like buying a shiny new porche and hitching a bloody great big caravan on the back of it everywhere you go.
megatron said:Goose -
Read this paragraph on the subject:
http://anniebrion.myby.co.uk/evenfaster-faq.html#para7
7. What if I am not downloading at my new speed?
If, after completing the speed test example above, you are still not receiving your full download speed, then there are a few more checks you can complete. Please check your Network Interface Card (NIC or Ethernet card) or, if you have one, any home network equipment, making sure it has a fully rated 10/100baseT port available to the Internet. Some older network cards and routers only have a 10Mb port, and these are not fast enough to transfer the data that is being downloaded. This gives the appearance that you are not connecting at the correct speed. You may also see this issue if you connect the modem to your computer using the Universal Serial Bus (USB) connection. Please try connecting your modem to your computer using a Broadband Network Interface Card, using a CAT5 (RJ45) cable, and after confirming that your network card and any other equipment does have the 10/100baseT standards outlined above. This should greatly improve your download speed. In addition, if you currently have a Motorola Surfboard, Model SB 3100 Cable Modem, you may also have the issue of slow speed. If you are a Blueyonder Elite customer (10Mb), please see the section below relating to having this model of modem swapped out.
You may also be able to improve your speed by changing your MTU (Maximum Transmission Unit) settings, take a look at http://www.speedguide.net/ for instructions.
Goose said:Thanks for that. My modem is plugged into my Linksys WRT54G wireless router. I would have thought that could handle 4mb as its a fairly modern router.
The MTU is set to Auto in my router and is 1500 by default if set to manual.
If anyone has any ideas i'd really appreciate it.
Cheers.
[Edit] Well thats odd, the Adslguide.org speed test continues to report that my connection is 2mb but im downloading at about 350k/s from gamefiles.blueyonder.co.uk.
I'm confused.
[Edit2] Forget that, its down to 275k/s so it definately aint right. The speed test here also says im on a 2mb (or less) connection.
[Edit3] After plugging the modem directly into the laptop the speed is now at 4mb according to the speedtest linked above. The adslguide speedtest says its a 3mb connection. I'm downloading from gamefiles.blueyonder.co.uk at 500k/s though (althought its dropping very slowly. I cant figure out if i have hardware/software problems or if its just a busy night.
Grrr.
