- 10 Oct 2006
More weight, higher fuel consumption, inferior handling, more tyre wear.
I'd be amazed if it got within 10mpg of the G30 530d - remember that has the benefit of being RWD instead of 4WD, too. Though 10mpg isn't exactly a 'small' hit in fuel consumption.
It's the elephant in the room in all this new-found petrol enthusiasm from government and the mainstream press - nobody seems to be mentioning the fact that the reason we have so many diesels in the first place is because our fuel is exceptionally expensive..
That did make me laugh a bit, I remember when you were telling people 8mpg wasn't enough to warrant a diesel over a petrol. I can only go with a couple of days in one, I am confident it will do 40-45mpg on a run, the most I have ever got out a F10 530D is a smidge under 55mpg which is identical to an xdrive 335d F31 so I don't think the xdrive system gives that big a hit. Of course they may have got a little more out the new revision of the 530ds engine.
Out of curiosity what makes you think the tyres wear more ? They do wear differently in that they normally all need changed at once, not a bad issue when you want to change the brand of poor factory tyres. The wifes Mini just got a new set at 40k. A FWD Mini would have been through 2 sets of front tyres and well through the 3rd set at the mileage with the rears not far behind. Similair story to my sister's S3s although the rears go 2-3k more than the fronts must have less rear bias.
