I thought the dealer replaces sensors when they do pads anyway.
I remapped the gearbox. It’s rather brilliant now.
I think we need more info
2. They've quoted me £1800! That seems high, but then it is an M sport plus running 19s and quoted from a BMW dealership so I assume this is the norm?
The M Sport brakes are large the fronts are 370mm two piece disks with 4 pot calipers.
£1800 must be a mistake the online service price for them at a local dealer is just under £800
You need to be careful if you go non OEM as the cheaper disks are not two piece and weigh a lot more. Brembo do two piece disks with aluminium bells for £280 ish pads are £70-90 depending what brand you go for.
The wear estimate is miles out mine says 4000miles to replacement but the dealer measured them as only half worn at 34k, the system estimates down to 1200miles then waits for the bad wear indicator to trigger before counting down to 0
I'll give them a call then and see what the deal is.
Looking at the report the front pads are 6mm, but brake discs are worn/lipped, advisory - repair cost £1808.16
Rear pads 5mm, nothing on the discs and no advisory.
Site says £620 - but also that "Prices will vary for vehicles fitted with M Sport brakes or Carbon Ceramic brakes (M models)"
£1800?Just had the car (F30 330d) in for a service (inspection 2), all went smoothly but they've flagged the front discs and pads as needing changing in 6000 miles. I've got a couple of questions really...
1. I'm sure that figure was much higher before I took it in, can they adjust that figure based on their own estimate, or is that a sensor thing and I've just not been paying attention?
3. I've tried looking for this info in the thread, but I'm not too sure still. Can you change discs and pads at an indy without it affecting your FSH?
I've just checked my e92 m3, it's 708 for my fronts so unless you have the same brakes and all 4 are being done. I've noticed on BMW's site that it says foc for battery recall even though it's a 13 plate, wonder if it's a **** up on their website?
LOL £1800 is literally insane. Absolutely barmy. This is the kind of cost I would expect from something like an Audi RS6 or R8, not a 330D. What age/mileage is your 330d on and are they still factory discs/pads?
I think I got my wires crossed between Texasjohn’s comment and MrMagoo’s.
I’ll put it down to being up since 3am.
That 340i is absolutely gorgeous. Great spec.
