How do you pass MOT with a DPF delete these days? I thought that they now check for smoke?Finally got the 5 back and looking like all fixed by a DP *cough* and a remap. Engine must have been choked on the exhaust as well as the intake.
My FD2 passes every year with the cat in the boot. Just have to find the right test centre.How do you pass MOT with a DPF delete these days? I thought that they now check for smoke?
Thats just wrong (for dieselsMy FD2 passes every year with the cat in the boot. Just have to find the right test centre.
You couldn't do that here in N.Ireland. Needs to be a DVA test centre rather than some garage.My FD2 passes every year with the cat in the boot. Just have to find the right test centre.
what's the strategy under the latest MOT then, to avoid smoke signals ... is that a special service from Deutch Tek.
Taking my car to Sytner next week, under the AUC warranty. Engine struggles to start (up to 7-8 seconds of the starter motor cranking) and yesterday it gave up during the first try but managed to start the second time.
Still has its original battery, so guessing it's just a battery change.
Doubt it's the battery. The batteries job is to turn over the starter motor which it sounds like it's doing just fine, there will likely be a problem with the fuel or spark element. Could be a bad fuel pump or crank position sensor?
The reason why I suspected battery (and to be honest I'm not very clued up on the workings of an engine, so could well be wrong), is because when I was cleaning the car a few weeks back, I had the engine off, but the radio on, and within 2 minutes I got a low battery warning.
Also, once the engine starts once then it will immediately start after. Only when the car is immobile for a few hours will it again struggle to start.
In any case, in response to your question: I have no idea
I've had the car for a month, so BMW will have to sort it out.
Interesting - I can see why you'd think it was that!
It certainly sounds like your battery needs replacing, but it also sounds like you may have a fuelling issue also. If your battery has enough power to give 7-8 seconds of good cranking and it's not firing, it's not going to be the battery that's causing your starting issue IMO. My E92 had a dodgy battery like yours for months (low battery notification after 30 seconds of having the engine off) but never failed to start or even struggle.
The 330i also had known issues with fuel pumps and injectors AND it's classic symptoms of a failing fuel pump for first starts to be difficult (as the pump has to work hard to bring the fuel pressure up after it drops from being left overnight) and subsequent ones to be fine so this would lend more credibility to a dodgy fuel pump. As the pump deteriorates, you'll also get error codes when you're flooring it as the pump can't keep up with the demand the engine is generating.
Good that you've only had it a month and it's BMWs problem though, let us know how you get on! Don't let them fob you off!
I'm going for a MAF/air-leak problem - if you feather the throttle when it's starting does is start better ? (presumably you start with clutch in)The reason why I suspected battery
be too easy for the garage to replace the battery speculatively if you are paying tooIt certainly sounds like your battery needs replacing
