- 11 Sep 2008
- Stratford-Upon-Avon
Thanks Fox, place round the corner can do 2 x Goodyear Eagle F1 Assymetric 5 on Saturday for £390 fitted .. seem to get good reviews so I'll give them a go..
Are the f1as5 run flats?Thanks Fox, place round the corner can do 2 x Goodyear Eagle F1 Assymetric 5 on Saturday for £390 fitted .. seem to get good reviews so I'll give them a go..
Iv been told never to mix non rfts with rfts
I'm not totally sure...I haven't really tested, but it seems to be that the apps will load automatically if the phone is unlocked at the point you plug it in.Can anyone tell me with the F22's iDrive is there any way for the media system to load my apps without having to actually use the app on the phone. For example, ideally, I'd like to plug my phone into the car, press media, go to Spotify and start listening. At the moment I have to plug it in, unlock the phone and start the app. It's not a huge inconvenience, but just wondered if this is standard behaviour?
Do you have android phone?Can anyone tell me with the F22's iDrive is there any way for the media system to load my apps without having to actually use the app on the phone. For example, ideally, I'd like to plug my phone into the car, press media, go to Spotify and start listening. At the moment I have to plug it in, unlock the phone and start the app. It's not a huge inconvenience, but just wondered if this is standard behaviour?
iPhoneDo you have android phone?
Thanks for this. Shame the combination isn't available in something smaller!Yes.
2010-2012 F10 523i and 528i and 2012-2013 F10 530i.
They are exceptionally rare - particularly the 530i (Only two for sale atm):
https://www.autotrader.co.uk/classified/advert/201905067677887?onesearchad=Used&onesearchad=Nearly New&onesearchad=New&sort=price-asc&fuel-type=Petrol&keywords=530i&make=BMW&model=5 SERIES&transmission=Automatic&advertising-location=at_cars&year-from=2010&postcode=s11aa&radius=1500&page=1
The 523i is somewhat unloved and can be very cheap:
https://www.autotrader.co.uk/classified/advert/201904076714533?year-from=2010&model=5 SERIES&sort=price-asc&radius=1500&onesearchad=Used&onesearchad=Nearly New&onesearchad=New&advertising-location=at_cars&transmission=Automatic&make=BMW&fuel-type=Petrol&postcode=s11aa&minimum-badge-engine-size=3.0&page=1
I'm currently in need of a second car and having driven one previously, I do like the E46 Coupe. I was looking at the 330ci's as people say they're a superb all round car.
Ideally I'd go for an M3 but it just seems to be a minefield and I don't want to be fluffing loads of money looking after one, or paying the kind of money it would take to get a mint version of what is already a fairly old car.
There's also the 330cd, which I guess is probably not worth it over the petrol, or is it actually good?
Anyone had one, any thoughts appreciated.
Well youre not married so not that much. You can order one from Russia for a couple of k. About the same for a Thai model. They tend to come very well painted.
Is the AC system actually blowing cold, air conditioned air? Mine (F11 Dec 2014 build) failed and the fans were just blowing none-cooled air about. There was a well known AC compressor weld issue. Car had to go into BMW for them to change it.
I am giving some thought to changing my RS Megane to a 3.0 Z4 coupe or a 125i coupe, as I'd like to experience the NA 3 litre engine before cars using it get too old. I reckon running costs might be similar?
Can anyone provide tips on what to look for in terms of pervious maintenance and specific things that should have been done? Any direct experience would also be fantastic. Thank you
