Post reported! I hope you get perma'dWith the ugly fronts
Thanks for clarifying that, will call them back just didn’t want to pay for something I didnt needIf it's due a Vehicle Check then this is part of the servicing requirements of the car. This is the inspection part of the old inspection 1 and 2 services, it was split out to be a seperate element when they moved to condition based servicing.
Whilst I'm sure there is an arguement in favour of not bothering, if you've taken it to BMW for a main dealer service for your history it would seem counter productive to then ignore the service schedule. So, if it really is the vehicle check element and not just some random thing then I'd advise doing it.
So it turns out unless they do the vehicles inspection the service light won't go out, wish they'd have explained all this when they called and quoted the service price! Told them to go ahead and do itIf it's due a Vehicle Check then this is part of the servicing requirements of the car. This is the inspection part of the old inspection 1 and 2 services, it was split out to be a seperate element when they moved to condition based servicing.
Thats pretty good, i think my e92 M3 was similar with the same excess (and also no breakdown). I took out warranty straight from the end of an AUC warranty so not sure if thats a renewal or not.F10 M5 £763 with a £250 excess, no Recovery (although a limited Recovery is included even if you deselect Emergency Roadside Assistance, if you read the Ts and Cs). Probably as cheap as it gets on an M5 as no lapse in cover.
Yes £250 is a high excess, but only really worried about being covered for major events like engine failure.
I have one of these. 2.8L straight six. Make a nice racket, is very nice and nimble. I picked mine for £4k with 62k miles on it. Did quite a bit of work on it so it's nice and tidy, but it's a very nice ride as a runaround. I think it's a steal for that money, you get a modern car, ABS, electric, heated seats, leather interior etc -- basically a really posh little car, that can still put a serious smile on your face when you plant your foot down.
Ended being sold before I saw it.Another car. Why buy a 320i?
What's wrong with it?Oh dear
Rain-X makes some popular products, their wiper blades, rain repellant and even their anti fog solution are very popular and can be purchased almost anywhere these days. Their most popular product, Rain-X washer fluid, can be the most harmful however to your BMW washer fluid filter which will eventually lead to a failed washer fluid pump.
Rain-X washer fluid has many additives in it to give it water repelling and bug removing properties. However, over time these additives can create a gelatinous solution at the bottom of your washer tank. This gel will clog up your pump filter and cause your lines to clog, your pump to overwork and fail or both. Additionally, if your nozzles go a little rogue and spray on your hood or roof Rain-X washer fluid can leave a sticky residue behind. None of these scenarios are desirable.
