@hurfdurf sadly I don't know if anyone that way. But you could says try owner groups/FB groups and see if anyone near by can code. That's how most do it.
Good idea
This man speaks sense!if you're setting them off regularly, i'm going to assume you don't indicate either, you might as well just take the bulbs out problem sorted.
What comes stock? You getting fade?I’m thinking about a 6 or 8 pot 360mm BBK for the i8. Good or bad idea?
Probably a better idea.Just change the pads and fluid, will most likely make a big difference.
Wouldn’t messing with the brakes on an i8 affect the regenerative braking ?
Edit: and calm...
I do wonder why some of you drive BMW's
How stupid am I not having warranty no my Z4 35is? Just had the renewal through, £552/year which is a nice discount on before BUT I'm starting to feel like it's a pretty solid car. I know I know, that's when it goes wrong!
But it's a 64 plate, so I believe it has the latest revision injectors and water pump which are two major N54 issues. Yes there's still the adaptive suspension which is big bucks to fix, and the roof I guess? I just feel like if it was going to need anything it would have happened by now (64 plate, 42000 miles) and it feels tight as a drum to drive still.
I'm going to regret it aren't I.
