Is your current car financed? If so call them up and see if you are eligible for a change.
Then the car would just be additional deposit. Whether you lose its value depends on the depreciation the new car suffers?
Not sure why you'd PCP in this situation.
The new Z4 imo is a huge improvement on the interior but a downgrade in every other department. I test drove a 20i and compared to my e89 23i it was far less exciting. Might explain why the sales figures on them are so poor. Also, no 6 cylinder and artificial sound pumped into the cabin is a massive put off.
1, a fluid and filter change - done properly - will have one of two effects, it’ll either transform it (pardon the pun) or kill it off completely!Hi guys,
A friend of mine has bought a rather ropey old E46 330i convertible as a bit of a plaything. He's under no illusion that it's not a bit of a shed, and he wants me to help him work on it including having a look at a few issues it has (mainly issues that I identified when I had a quick go in it after he bought it):
1. It's an auto, and it feels thoroughly kaput. When you put it in drive and come off the pedal / get on the throttle, there's a short delay and then take-up occurs in a way which could be described as violent. It then slushes and slips/jolts its way through the gears, occasionally going in to limp-home mode / getting stuck in a higher gear with a cog icon on the dashboard, necessitating a "reboot" (engine off and back on). Will a fluid and filter change likely sort this to some degree, or is it knackered?
2. Power delivery is buttery smooth, but it doesn't feel like it has 230bhp (when the gearbox is behaving itself, I mean) - VANOS?
3. PAS appears to be non-existent - wheel is very hard to turn when maneuvering at low speeds - not quite as hard as a car with PAS that you're trying to move without the engine running, but not far off. PAS pump dead? I didn't check the fluid levels.
Alarm bells did ring when he told me he paid a grand for it![]()
Took my Z4 for 2 weeks for them to try and replicate the error.
I've just topped up the oil in my e92 m3. How longs reasonable for the car to realise its been done? I put in about 4-500 ml last Thursday and it still said top me up so I finished the rest of the litre tonight. I'd have thought a few days would be enough, or did it literally mean add 1 litre? I was trying to be cautious to start with as I'm not a fan of electronic dipsticks.
Yes, a bank loan. Quite often they work out far cheaper than dealer HP. Or a 0% credit card if your credit rating is excellent.I'll look into hire purchase. Is it arranged soley through BMW or are there other options?
I have a 2010 Z4 35iS, does the new Z4 now handle way way better because it weighs so much less?
A 0% credit card if your credit rating is excellent.
This. Although with credit card fees of up to a couple percent, you can see why. Buying a £20,000 car on a credit card will mean a fee of up to a grand!Good luck finding a dealer that will let you put a car on a credit card. Even debit getting is getting difficult these days. Very annoying.
