- 14 Apr 2014
- Hampshire
I’m only pulling your leg mateI somehow doubt I am the only person who has not had a BMW engine fail just for following the manufacturers servicing schedule.
So after being quoted £256 Inc vat on the phone from BMW for oil / oil filter and air filter. Ita apparently £350 . What is an environmental charge ???
They can't just quote one price on the phone then increase it when you here
Two sytner BMW dealerships I phoned and they both quoted £256 Inc vat
They have gone to apparently listen to the call
Edit: mistake on their part. I also love how they said there is no oil change scheduled on my car for another 15k miles..
Why?
Glad you got it sorted.
Because they go by what's on the dash..IE oil service every 20k. And i don't leave it this long. I will probably leave it 7-8k miles before I get the oil done again after this one
Sounds par for the course. The body shop put my car through a regular car wash after having fresh paint on the rear panel. Boggles the mind reallyThey ignored my request to not clean it . They done it anyway. Ah well.. the wax is still good on it though .I just tipped some water on it and it still beads really good..no idea what they used to wash it with and how they done it. Hopefully a jet wash and not scrubbing it with a sponge
Not going to ask
Not going to ask
Oil filter oil and air filter change came to £241 which included vat
Seems to happen a lot. I’ve watched the car cleaning ‘team’ at most main dealers and they aren’t usually much better than the generic hand car wash places.
Depending on how annoyed you are, you could request they pay for a detailer to polish the car to remove any of the inflicted swirls. I’d probably do this if I’d just spent time correcting the paint and then they washed it when I asked them not to…
If you don't use the air-conditioning this can mean it will fail sooner rather than later but I'd expect it to last longer than 6 months without use. I've had my car from new for over 6 years and I always leave the air con on, usually to heat the car rather than cool it.Healthcheck wise the only thing that came up was rear pads 4.5mm advisory and a reccomended air-conditioning regas service which I found odd as I dont use the Aircon and I bought it in Feb /march this year from used approved.. why would this need doing so soon when I have not used it ?
Healthcheck wise the only thing that came up was rear pads 4.5mm advisory and a reccomended air-conditioning regas service which I found odd as I dont use the Aircon and I bought it in Feb /march this year from used approved.. why would this need doing so soon when I have not used it ? Worth asking the place I got it from to see if they can look at it here if they missed this ?
Why don't you use it? It's better to leave it running and let the climate control system sort everything.
Did they actually recommend a regas or was it their air con cleaning thing? Most dealers are trying to push this as part of a service nowadays...
Speak to them, see what they say. Explain you’re particular about your car and that you’re not happy they ignored your request which will be reflected in your survey response and public reviews.They ignored my request to not clean it . They done it anyway. Ah well.. the wax is still good on it though .I just tipped some water on it and it still beads really good..no idea what they used to wash it with and how they done it. Hopefully a jet wash and not scrubbing it with a sponge
Not going to ask
Should run it all the time or at least a couple of times a week to keep it running.She said something about checking piped and regassing. I only generally use it when the weathers hotter
Why wouldn't you leave it on all the time?She said something about checking piped and regassing. I only generally use it when the weathers hotter
I will start using it moreWhy wouldn't you leave it on all the time?
Shouldn't be case of using it more, just leave it turned on. There is no reason to turn it off at allI will start using it more
