After small research with potential problems that possibly could go wrong with my Z4, Any things I should look/hear when it comes to the Vanos? The car is on 87k right now and unsure if its ever been sorted previously.
Cheers.
Which engine is it? The below is based on my experiences with the M54B30 (330ci).
If the VANOS seals are the same material as used on the E46 (and probably many other models), they're probably long past it already. From memory, early E46's had running issues when the seals detoriated, which prompted BMW to release a software update which allowed the engine to run without noticeable issue.
I can almost guarantee that the old seals will be past it. Beisian systems reckon the original material isn't good enough and they will deteriorate, but the ECU will compensate to the point where the driver won't really know there's much up.
From memory again, the main symptom was a loss of low end grunt, and from personal experience, there's a 'shunt' of power when you go over 3-3.5k RPM.
They're reasonably easy to replace, if not a little fiddly, and I'd probably recommend changing the rocker cover gasket if it's not been done before. I6Automotive do a seal kit which is well regarded, and a full guide with pictures can be found here:
http://www.beisansystems.com/procedures/
