Boot problem after installing SSD
17 Feb 2009
Leeds
Hi all. Installed my new SSD today, all went great. Got my essentials installed onto it and tweaked it up, changed the boot controller to AHCI, etc. All working fine.
I've just gone to plug my old hard drive in (still has all my old data on) and when I went into BIOS just to check the boot order, I couldn't see my SSD? Only my old drive and CD Rom. If I unplug the SATA cable which goes into my old drive then it works as normal. On a whim I tried booting off it and it wouldn't boot.
Anyone got any ideas? Thanks.
Gave it a shot, wasn't able to repair anything/did nothing.
Also tried a different SATA port to see if that was the problem, same issue. :(
Try booting from ssd then connect the hdd while in windows,then asign a new hdd letter to the old hdd
Thanks for the help. Plugged it in, assigned a new drive letter and started formatting it through Disk Management. Will let you know how it goes. :)
Well, formatted fine and cleaned everything off it. Gave it a new letter and restarted. Same problem. :(
It was just looking for a boot medium, went into BIOS and it can see the old HDD and CDROM in there as a boot priority just not my SSD! Weird though as the SSD is being recognised in the SATA listings.
:confused:
Sometimes in the BIOS there are two lists:
1. Boot priority
2. Hard drive priority
1. The boot priority list shows types of drive availbable (optical/hard drive/USB)
All the harddrives (both mechanical and solid state) are lumped under the hard drive category and only one name is shown in that list.
2. Then there is the second menu to set the hard drive priority.
Whats probably happening is that your hard drive priority defaults to your mechanical drive first, with the SSD second. If you swap this round the SSD will then show in the first list and you should be able to boot.
I had read about this before and had a quick look in there to see if I could see anything of the sort and couldn't. BRB while I check again...
