I've been in the E92 and while it's more modern design inside, I still think the E46 cabin has a more nicer direction to the quality of materials used. The doors are heavy, the door handles inside have weight to the pull, the seat backs are padded and not hollow plastic, the plastic sills are all smooth and solid instead of scratchy light plastic - List goes on.
Definitely agree with you there. My E92 interior was disappointing to say the least.
[TW]Fox;27642741 said:Stay away from the F30 then![]()
Tomorrow I'm coding the Bi-Xenon flasher mode in exchange of the default E46 Halogen = flasher, and also a few other bits (walk me home duration, triple indicator, additional comfort access and lighting stuff etc).
Are you coding them yourself or getting someone to do it? If yourself, can you do E92s? I have electric folding mirrors but they don't fold on lock/unlock, willing to provide tea tokens if you're able to do it![]()
Glad it's all going well, the joys of buying a lovely example
Just to add to your point about the interior on the E46, I took the drivers door card off the E53 to get at the door carrier and I couldn't get over how heavy it was.
Not that weight means quality, but it just reinforced my opinion of that the interiors of that era of BMW was a high point.
I gave that a go without success on Friday, but I'll admit to not having really had the chance to play around with it so it could be operator error. Will try again once the car's back on the road and I'm using it again.
I have the cable and laptop software but I also have the Android app so for the quick coding stuff I used the app (BMWhat). Seemed to work alright:
http://robbiekhan.co.uk/root/temp/rps20150217_211139_166.jpg[img]
^That feature is cool but it also flashes the Halogens if the Xenons are on. Naturally it flashes the Halogens if the Xenons are off so I'd like to be able to tell it to not flash the halogens if the Xenons are on - If anyone knows of a way to do this that would be great![/QUOTE]
That looks exceptionally easy. The Bi-Xenons not flashing on the E46 used to really bug me, the halogens just didn't look anywhere near as good!
[quote="kona786, post: 27645765"]Also on my Dad's F10 you have to fold the mirrors with the key fob (hold down) for the mirrors to auto unfold when unlocked.
If you fold the mirrors from the interior button they won't auto unfold.[/QUOTE]
I had been messing around with the button to fold them in just before come to think of it, shall try leaving it well alone and then using the key fob, thanks :)
lol[TW]Fox;27649590 said:Yea, because one thing thats on your mind when flashing your full beams momentarily is how good they look![]()
