 - 20 Aug 2003
 - Pembrokeshire
Ecoboost?
			A lot of what you have said in this thread is absolute pish.
Of course they know what to repair/replace. They cant just go ahead and replace the engine under warranty without authorisation from Ford. Ford will send out the new engine (or bits) and the dealer will fix it. The strip down and replacement of engines is very costly to Ford as it is them that foots the bill from the dealer (labour and parts). They wont allow garages to do it willy nilly.
Its quite obvious by your other posts in this thread you have a massive chip on your shoulder against garages/dealers yet have no idea how they actually operate.
All I have said in this thread is what the service guys in the dealership have said to me and this has been passed onto you by me saying "They" as I am not fixing the issue myself as its under warranty and have not put a foot in the car since 5 minutes after the fault first occurred.
They do not know what to replace/repair as they still haven't figured out what the problem is and that is why they are on the phone to ford technical
....are on the phone to ford technical on what they need to replace as they obviously don't know themselves![]()
I fully understand how garages work with the manufacturer footing the bill as the garage in question is a franchise
Turns out it was a spark plug. They have no idea where the coolant leaked from as well. They still have the car testing everything is ok by putting some miles on it probably using it for a delivery van![]()
The rolleyes is because they do not know what is wrong with as I previously stated and I would have thought someone has a franchise in a company would know all about them.
A lot of what you have said in this thread is absolute pish...
Jeez what's with all the bad attitude to Skywalker?! Is there some more history going on here? Perhaps you work in a Ford service dept?
 (yes I used a rolleyes)
List of damage/failures being replaced/fixed
Short block
Cylinder 2 (cant remember exactly what)
Head gasket
They have told us earliest of end of next week the car will be fixed, So in other words the week after that.
To top it all off when we where there last the car was on axle stands as 1 of the tyres was flat due to damage/punctured tyre
