budget build
3 Aug 2014
Slamannan Falkirk
I thought I would put a thread up with my build details..
as I say in the title its a budget build but I will be doing upgrades through time.
spec so far..
CPU FX 6350 (Zalman CNPS5X Performa cooler )
MOBO Gigabyte GA-970A-DS3
12.0GB Dual-Channel DDR3 @ 800MHz ( just changed this as was running at 671 MHZ
GPU msi 7950 O/C boost edition ( GPU Clock 1000 MHz, Memory Clock 1250 MHz )
be quiet power zone 650 watt psu
PSU 1tb seagate system drive
Storage 2tb seagate slave drive
zalman z9 plus case
upgrades I'm planning at the moment..
SSD for system and programs
newer mother board
fx 8350
I also want to add a Blu-ray writer drive as ive sold my ps3 so no longer have a Blu-ray player.
Im half tempted to go crossfire as I can get my hands on an exact match for my GPU Im just wondering if I would see the benefits
Ive just upgraded my monitor to a Samsung SyncMaster 2333sw from an old dell monitor so the difference in my games is amazing.
Ive being playing watch dogs and just cause 2 and it plays them smoothly with no stutter so ive no complaints.
there is stuff I would like to upgrade through time but for my first gaming build im happy so far.
Ive bought a pre owned asus sabertooth r2.0 so that's on its way to me.
so hopefully once this arrives ill get both my 7950's in and get some good frame rates going..
Ive also swapped my cx750 back in. Ill get some more pictures once the new board arrives and is installed.
Ive also been wondering why my ram has been showing as running at 800mhz...
( corsair vengeance )
I've now discovered that 1600mhz ram shows as 800mhz within windows.
I googled it rather than asked thankfully..
Using an ssd as a cache for your storage drive should give you a nice boost. I use that on my x58 system and it made a big difference.
so Ive been having a look in this new BIOS and I chosse the performance setting and its took my cpu from 3.9Ghz to 4.23Ghz and it all seems to be pretty stable..
Ive not really messed about with anything else bar setting my 2 Msi 7950's up and so far im really pleased with the difference in just a new board
ive just had prime95 running for around 30 minutes and all good..
yet with the old board I couldn't get it past 4.1Ghz and run prime for 10 minutes without dropping a core.
so after playing a few games ive noticed a fair drop in frame rates when running crossfire compared to just one 7950.
now I know I get a better score in valley but my thoughts is its in games where it counts. so ive pulled the second card out and tested both separate which they both seem to be giving me pretty constant results on a benchmark test in just cause 2 ( concrete jungle )
so plan is im selling one of the 7950's and using the proceeds towards an ssd drive and through time im going to go back to an nvidia card and try sli and see how I get on with that.
What games? Xfire support isn't universal and there will always be the dual card gremlins to iron out mate.
the 2 games ive been playing the now is watch dogs and just cause 2 both of which are running smoother with a single card.
doing a benchmark in just cause 2 ( concrete jungle ) in crossfire I couldn't get over 57FPS where as with a single card im getting 97FPS
Theres a lot of people who get negative scaling with Watch Dogs in Crossfire, it's probably best to not use that game as a yardstick as it's been in various states of broken since launch.
What results do you see in Firestrike?
Im wondering if the FX8350 will be a worthwhile upgrade.
Ive been offered an Asus formula z board and an FX8350 for a good price.
Im still in 2 minds as to keep the board ive got and just hang off and get the 8350 on its own though.
