Build 5 TJ07
The fittings and tube are 7/16 I feel 1/2" tube takes over the visual IMO.
I have an ax1200 psu so I may go with the rx120 down there too. When I took the 800d apart, I ran with a 360/120 and the temps didnt budge bit I guess if there's room - use it.
How come your limited with the ram blocks PGI?
GA-X79-UD7 has two banks of two either side of the socket, afaik EK have only ever made the 'X2' ram blocks in the CSQ design. I'll make it work though, fairly sure it has some 3mm LED slots, so I'll mask it up with some orange LED's.
I can't remember if its the TJ07 or TJ11 that can handle a quad and double rad at the bottom with an extended PSU. Get the tape measure out :D
slow progress
Very simple to make if you know a laser cutter. This one is bought as I could not get the light to balance on my DIY one. Easy to buy and cost effective
how did you make the lighting panel for the floor? Any tutorial on making one? Would love one for my rig!
Thanks
A few tweaks and finishing up
Behind the scenes
Cabled up
Going to put a few LED's in the roof to balance it out. Anyone know what the Bitfenix 6LED lights are like. I want a warm white glow
