Now that most of my parts have finally arrived I figured I'd start a build log!
This will be my first build that I have either modded or water cooled so should be interesting.
The name "Initium Novum" means New Beginning in Latin, I Thought it was fitting seems this build will be using my TJ07B that has been in use un-modded for 5 years or so.
Components:
i7 4770k (Haswell)
Gigabyte Z87X-OC
4x Samsung 840 Pro
4x4GB Corsair Vengeance Pro series 2133
Asus Xonar D2X
Highpoint RocketRaid 2720SGL
Silverstone ST1000-G
Asus GTX 580 Direct CUII
Water Cooling:
Hardware Labs Black ICE GT Xtreme 480
EK Supremacy CSQ Nickel
Phobya Balancer 250 - Matt black
Alphacool VPP655 with Black D5 top
EK FC580 DCII Acetal+Nickel
Monsoon 16/10mm Matt black fittings
Aquacomputer Aquaero 5 LT with water block
Aquacomputer Ramplex black
Mayhems Pastel - Gigabyte Orange
Corsair SP120 fans
Inset terrible quality picture of pile of goodies. (will replace when I pile all the boxes up again, didnt realise it was this bad
Colour scheme is going to be black and orange, seems to make sense with the motherboard being those colours, So I've got the orange fluid, black fittings and ordered some black and orange acrylic which will be used for some custom parts using the laser cutter at work.
Before I started this thread the case had all ready gone to ChilledPC to be black powder-coated internally and be switched round to inverted ATX.
I also had the grill in the top enlarged to fit 3x120 fans and that will be receiving a new grill custom made from the acrylic.
And have started sleeving the psu cables with paracord.
Painted some of the rings from the fans too.
Components:
i7 4770k (Haswell)
Gigabyte Z87X-OC
4x Samsung 840 Pro
Asus Xonar D2X
Water Cooling:
Corsair SP120 fans
