corsair branded > http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-CS
40 smackers,
40 smackers,
Ok guys we gotta keep this under £500, just spoke to the buyer, the corsair is the PSU I would like to go for though.
Thanks for the builds so far, really like the Hexcore system, anyway we can make cuts in it?
All of that for 400 pound would make it pretty hard if not impossible.
The essential programs are photoshop, vray, rhino, sketchup, cad and indesign.
What is the most basic MOBO I can get to work with the Hexcore? Since I will obviously need a standalone GFX.
This is what I have come up with, not all from OcUK though.
Processor
AMD Phenom II X6 1055T 2.8GHz 9MB Cache Socket AM3 Retail Box Processor 204939 60 in stock £155.99
Monitor
Cream 18.5" Widescreen LCD Monitor - Glossy Black £79.89
Motherboard
Gigabyte GA-880GM-UD2H 880G Socket AM3 8 Channel Audio MATX Motherboard 218935 14 in stock £69.09
Memory
Patriot Viper 4GB (2x2GB) PC3-10666 1333MHz Dual Channel (PVS34G1333ELK) £70.49
Graphics Card
XFX GeForce 9800 GT 512MB GDDR3 PCI-Express Graphics Card £58.74
Power Supply Unit
Corsair 400W CX PSU - 12cm Fan 80Plus Certified Efficiency 6x SATA 1x PCI-E 150985 684 in stock £34.55
Hard Drive
Samsung SpinPoint F3 500GB Hard Drive SATAII 7200rpm 16MB Cache - OEM 146252 > 5 in stock £34.98
DVD-RW
Samsung TS-H653G DVD-RW SATA Optical Drive - OEM 227080 > 200 in stock £13.99
Mouse and Keyboard
Black Wireless 2.4GHz Multimedia Keyboard and Optical Mouse with Nano USB Receiver 196051 1798
£12.99
Total without case = £530.71
I really think that a cheap PSU is a false investment, because it IS likely to take other components with it. Use the computers in the labs for a while and save up an extra £50. Even students can expand budgets.if there is a potential for upgrade within say 6 - 12 months down the line then psu would be fine with the clear knowledge it isnt great and may go, just got to hope it doesnt take anything else down with it.
The gpu should be fine for reasonable sized projects but there will be a time issue involved especially for rendering.
The dell monitors are fine but then that depends on how much clarity you want on lines and curves, most of the lower end dells ive had dealings with have been pretty blocky with text and fine graphics.
But even after saying all that, that is a great build for the price and limitations are going to have to be expected for that price. Im surprised to see a 9800 that cheap the price really has dropped on those
Hi All,
I am looking to build a computer with a maximum budget of £400 that will run the programs: Vray (rendering), Adobe Photoshop CS5, Adobe InDesign, AutoCad, Rhino 3d Modelling Program, 3d max, sketchup and flamingo rendering with no problems.
I can’t remember whether this type of work required more cores or more Ghz.
Thanks for the spec Phoenix...are you sure I can do away with the gfx? One requirement is to not have to wait around for ages when using the programs!
Thanks
