Building a computer
We managed to get it working
when putting windows onto your computer, what is the difference between x86 and x64? i went with x86
also i have a thing in with my graphics card that says crossfire on it, does that need to be kept/stuck on anywhere?
Glad to hear things are up and running.
Should have gone for x64 (64 bit).
When installing Windows7 you should have 2 installation discs. One for 64 bit and the other for 32bit (x86).
You should reinstall it with Windows 64bit. Save anything you need from the hard drive, pop in the 64 bit disc and boot from the optical drive. It should give you an option to format and reinstall.
Is it a Crossfire Bridge (Google it). If you only have one graphics card then you don't need it.
x64 is the 64bit os version. this is the one you should be using if you have more than 3gb of ram.
the thing with your graphics card is a crossfire bridge, you only need that if you have 2 gpus installed
edit. beaten to the punch :p
Yer I was beaten too, had it all typed out, bah too slow. :(:rolleyes:
I'm glad someone else thought it was a crossfire bridge he was referring to? For a minute had no idea what he meant!:D
well i should know, my first ever build last year, i opened my vapor x 5770 and installed it, then sat for about an hour too scared to turn it on because i couldn't figure out what to do with the crossfire bridge that was left in the box :p
Done this
but it's giving me this option
disc 0 partition 1. system reserved (e) 100.0mb free space 71.0mb
or
disk 0 partition (c) 931.4 gb 920.gb
which one do i choose? the bottom one?
Did it give you an option to format the drive when doing a reinstallation?
i'm not sure now, am i best going into the bios and deleting all the partitions and doing it that way?
also it won't let me go on the net, I've plugged the ethernet cable into it (which worked half an hour ago on my old computer) and the net isn't coming on, do i need to download any like network drivers?
Not sure about deleting partitions via the BIOS?:confused:
Try resetting your modem/router firstly. Have you installed the drivers from the motherboard CD if you can't get online?
Is Windows installed on the first partition of your hard drive? (C)
Were any other hard drives connected to the motherboard when you reinstalled Windows?
sorry i meant putting it to run the cd first in the bios and then running windows, (i'm going on what i did on my old computer)
i also chose the (c) option that i put in my earlier post so surely it will be?
only the one harddrive was connected to the motherboard (as far as i know)
yea you put the cd into the drive and in bios set the pc to boot from cd drive and you'll get the prompts to install. but if youve already reinstalled windows then goto my computer and look at the 'c' drive and see if shows as partitioned or does it show the (almost) full 1tb of space available
Boot priority wouldn't matter as long at the hard drive is #1 or is #2 (with optical drive as #1) but with no CD/DVD in.
So your hard drive should now look like:
(C) New installation of Windows
(E) System Reserved (aprox 60Mb of 100Mb)
Nothing else.
As before, use the CD that came with your motherboard to install the network/chipset driver and/or any ultilites you want on there.
On My computer it says this
hard disc drivers (1)
local disc (c:)
912 GB free of 931 GB
so is everything ok? and my dad has my motherboard cd and is at work :mad:
local disc (c:)
Yeah that looks ok. Looks like Windows has installed onto the first partition fine.
Right click on "My Computer" "Properies", under "System" it should now read;
Installed memory (RAM): 4.00GB
System type: 64-bit Operating System
Just to confirm the 64-bit operating system has been installed.
No luck with resetting the router? Try restarting the machine if you haven't done so since the latest installation of Windows.
