Yeah, seen this, will probably go for it around the holidays if I don't see anything else.
Use a battery pack, a multi-charher than can do 100W across up to 4 devices with a single travel adaptor. Then an hdmi to usb c to hook up to monitors if needed.
Was looking for a nice pack to put all my wires in, what is everyone using?
I'm surprised how many of you are using junk cables and TEMU plugs to charge 1K+ devices.
A lot of it is just rehashed anyway into a different shell anyway if you buy in the UK.
I've never actually had a problem with any Aliexpress stuff as chargers go.
My rav power powerbank got wet and blew but still didn't take the device it was connected to out.
Very nice and pretty much what I put together for myself yonks ago to keep iThings and digital cameras powered on holidays and then for work trips where The Techno Bag was simply slipped into my work bag pack with my laptop.
Yeah I'm not sure how it works with a captive portal but I am told it does. The NIC isn't required all the time. There are lots of YT videos including an LTT Short Circuit.
After some research I have the Beryl AX in my basket lol. It has wifi 6, USB-C powered, double the cost but more future proof.
I looked at both the GL.iNet GL-MT3000 (Beryl AX) and the GL.iNet GL-AXT1800 (Slate) as a VPN bridge between my daughters university room and my home. Her uni room had captive portal and, although I had got a previous travel router working using MAC cloning, it often disconnected. I can't remember the exact differences between the two devices but I came to the conclusion that the AXT1800 would be the better device. I'm fairly sure this was due to better captive portal support. So I installed one at home as a VPN server and one in her uni room as a VPN client bridging to her rooms wifi with captive portal. It worked perfectly.
I did a thread on it here:
Getting non-captive portal devices working in student accommodation
This isn't a question because I worked it out. But I found it difficult to search for. So I thought I would document it here for others to be able to come across with a search. Basically I'm just adding this so Google finds it to help others. There may be simpler ways of doing it but it's how I...forums.overclockers.co.uk
You can get much higher than that even, much higher.Excellent thread. @Hades - love that adapter device, might have to get one.
Also had no idea you could get 100w power banks as well.
Shargeek 170
Transparent Prism Silhouette. 3-device Fast Charging. 170W Max Output. 140W Max Input. Recharge from 0%-50% in 20 Mins. 24,000mAh All-day Power. Smart Display. IP66 Water Resistant.sharge.com
