Bum! Excel 2007 help?
Permabanned
9 May 2005
NE8
We have a spreadsheet...That for some reason types # instead of £ and / instead of #...
It only effects this spreadsheet...Checked keyboard and language...Both are UK English.
Any ideas?
*n
You checked the language setting inside excel or is that what you meant when you said you've already looked?
If not, start, microsoft office, ms office tools then language?
Tried it - it only affects this spreadsheet though :( Even if I open a new sheet in this instance of Excel, it doesn't have the problem... :/
*n
*n
Is this a pre-created spreadsheet then? I.e. it has some data already there which you need to keep? If so, try copying the data to another spreadsheet and see what happens.
