- 2 Jun 2004
when cooking pasta?
Middle-class student by any chance?
when cooking pasta?
No, reader of instructions on packet...
You're too late!
The oil worked anyway, it didn't stick this time but it still tastes as rotten as last time I made it with just water. I also burned the bacon I have added to the pasta so overall a fairly disgusting meal.
Forget oil in the water, it's useless.
I've never understood the fascination with adding salt to everything..
Personally I find salty food dissapointing, not to mention unneccessarily unhealthy.
A common misuse of the effect of ebullioscopic increase leads to add salt when cooking pasta, only after water has started boiling. The misconception is that otherwise it would take longer for water to boil to elevate the temperature of the water before it boils. However, at the approximate dosage of salting water for cooking (10 g of salt per 1 kg of water, or 1 teaspoon per quart), ebullioscopic increase is approximately 0.17 C (0.31 F), but it is counteracted by the fact that at that concentration salted water absorbs heat faster.
Actually, it breaks the surface of the water and prevents it from boiling over. I always use a bit for that reason.
As opposed to adjusting the heat?
Get the temperature right and it shouldn't boil over.
I always thought actually boiling it is better than a simmerIndeed. Should be a simmer not a boil.
