- 12 Oct 2007
and the card would run fine on the mobo, being an old board and that, also is it an AM2+ or just AM2 board?
If this is your motherboard then it supports both AM2 and AM2+ CPUs. It will work perfectly well with any PCIe graphics card. As has been said by others if you have the chance to get the GTX280 within your budget then you should get it over the 260 but either card will be excellent at that resolution.
Edit: Ahh Loadsa got there first.
oooowwwww!!!!!!!! hope it goes well for you
