Cant get new sofas through living room door
30 Jul 2005
Midlands
So got my new sofas from SCS the corner suite got in through the front door and then into the living room door easily since it was all sectional pieces.
The larger maxi sofa which is the 3 seater type is taller than the door and not much room to maneuver it through. Its in the house but not in the living room.
I will get some pics up in few mins.
Hopefully someone can work out an angle i can get it through.
The delivery people didnt want to take the sofa out of its packaging and move it around and risk damage to sofa or property.
Iv got 2 heavies coming round to help me in the evening but probably best i get a plan of action ready
Oh dear! My experience is that things that seem impossible to fit through CAN fit if you find the right angle.
Serious, but also...
The first thing I'd do is take off all packaging, legs and cushions and see if you can try again. Had to do that with our sofa and managed to just squeeze it through!
i cant take the window out its a multi frame thingy one.
here are the pics
Put the bottom in first, with the top angled against the stairs, rotate it towards the right with the back of the sofa going in first and then rotating through the door. Pull the bottom through as the top slides down the stairs and maybe towards the left.
