is the clifford turbo timer built into the intellistart?
Serious question...
People here are recommending it saying its great... have all these people had people try and car jack them? I don't mean to be confrontational, I just can't honestly say I've seen the need for something like this.
just a question, with intellistart, if use the cliffnet wizzard and adjust the crank time does that mean it will pulse the intellistart to crank the engine for longer if it needs to? because mine some times if low on fuel it wil crank but then stop and restart it because the engine has not had to to start
thanks
I heard It's annoying especially if its been fitted with scotlocks. I like toads smoke clokeHi
Does anyone have any experience using this car security system or have one fitted to their car?
If you have:
How do you find it? Easy to use?
More hassle than it's worth?
Has it ever not worked properly and left you stranded? What did you do to dis-arm it?
What do you do when other people want/need to drive your car, do you dis-able Blackjax?
Thanks
P.S
If any of you reading this thread dont know what the Clifford Blackjax system is, it's basically an anti-hi jack system that cuts power gradually and then once the car has stopped the alarm sirens go off and the headlights/indicators flash so the thief does a runner.
It works by you having to enter a code whenever to get in to drive the car, if you dont enter the code the anti-hi jack system enables.
or fit them using 1000 scotch locksCorrect Answer.
Same applies to Remote Start. It's not tested and doesn't interfere with the alarm.
I am a Clifford Approved Installer. Excellent systems as long as they are fitted properly. 90% of issues are caused by installers who don't know their way around a clifford's wiring system and setup.
