Man of Honour
- 29 Mar 2003
- Blurton
No-one here could![]()
I've done marathons
If you were in a very large featureless field that stretched for 1 km in each direction, and you and a very skittish cat where at the centre of it, do you think you would be able to chase down the cat and catch it? They can run very fast at short distances but I wonder how it things would work out in such an environment with longer distances? if you like you can substitute the cat for a hare or other small and fast animal that you wouldn't expect to catch by hand.
How big is the cat, is it likely to want to eat me should I catch it?
How long is the grass and what colour?
What way is the wind blowing?
Is it day or night? Cloudy or clear?
You think theres not a single capable runner on the forum? I think he more probable issue is a 1km field is too small. If it was a 1km room, I'd take bets on the forum, but I wouldn't wanna kill a cat to prove my point.![]()
If it gets past the 1 km threshold the experiment has failed.
Still don't think it would work. For a human to run long distances he has to run slowly, this gives the cat plenty of rest breaks and cats can retrieve energy very quickly.
Haile Gebrselassie, for example runs a marathon at 12 mph, a cat can run at 30mph so it would take an endurance runner almost three times as long to catch up with any cat run. Thus I predict a cat would run 50 metres, stop and wait the 12 seconds or so for the runner to catch up in which time it could regain almost all it's energy then set off again and repeat.
The cat wouldn't just run continuously, it would stop every time it had a decent gap thus cancelling out any long range running a human has.
I've done marathons
The method is tried and tested on antelope, so I figure it'd work on a cat.
I've run long distance myself.
Cats are too quick on their feet. It isn't about straight line speed.
You need to be quick enough, nimble enough, have enough stamina and have enough dexterity whilst moving.
Just not possible.
No, but their spears did.
There's also more than one of them.
Dexterity and speed never came into it. The kudu he's hunting can hit 60mph.
This shows me you didn't watch it yet.![]()
