As far as tuning boxes go I think these are amongst the better options out there. As others have pointed out though, it won't be as good as a proper remap. I think that's fairly obvious and not really up for debate. I'll be interested in your feedback on the economy side of things as my understanding/personal experience is that whilst many remaps and tuning boxes claim better fuel economy very few actually deliver and, if they do, the difference is miniscule.
If your engine is making more power by upping the boost and therefore injecting more juice - and if you make use of that extra even a relatively small percentage of the time you are going to use more fuel...
If you go down the piggyback ECU route with a chip its just going to be fighting with the maps on the stock ecu and the check engine light will stay on.Danger to the manifold, blow the welds on the intake etc etc, now thats over withIf you go down the piggyback ECU route with a chip its just going to be fighting with the maps on the stock ecu and the check engine light will stay on.
If you can remap the stock ecu this imo is the best option but takes a while and testing.
The proformance gains from remapping alone as a rule of thumb are roughly:
Petrol N/A 10-15% BHP and up to 20% torque
Petrol T 20-30% BHP and up to 25% torque
Diesel T 30-50% BHP and 60-75% torque
As you can see the diesels will gain the most as they are detuned with a 'catch all' map, but with remapping to get it running the best it can you are going to needing servicing more reguarly in some cases about twice because of the increased stress.
Which car will do this?
Sorry it was a rather sweeping statement, I have seen it happen in the same car as I have, colt. And seen reports in a few others from discussions on the openecu forum.
I agree it defiantly does depend upon the engine and obviously the better performance cars the better tuned they are going to be as stock. Those numbers are very ballpark and where more to illustrate the ratios of improvement between types. The numbers came from a ECU tuning service website so probably a bit of marketing there
Heh I'l just do and sit over here![]()
The manual which came with the CRD module says the module itself has fine tuning jumpers which can be used to increase/decrease the performance by 10% steps up to 30% each way. This is just in case the power I too low or high.
Why would you buy a Polo GTi or a Lupo GTi, mahybe cause they are small, quick and economical. Plus You might want to fit a turbo or charger cause you want to. Why would you want to remap any car casue you want it to go faster cause you like the car
