Very first world problem. UDM SE cannot get more than 1400Mbps down on 2GB connection from Aquiss. Martin did advise it was underpowered. I'm very much tied into the Unifi system for cameras, sensors, Wifi so did not ideally want to change and I'm sure I can live with this but realistically what are the options.
- Sell the UDM SE. Get a new router that can do decent pppoe speeds and have Network run on docker on my nas to control the ap's and buy the Unifi NVR for protect
- Run double NAT with a decent router in front of UDM SE
- Live with current setup...
I'd have thought it would be able to do higher, I'm sure I've seen users posting speed tests closer to 2.5 Gbps. There were also some EE users on Openreach testing at 1.6 Gbps.Very first world problem. UDM SE cannot get more than 1400Mbps down on 2GB connection from Aquiss. Martin did advise it was underpowered. I'm very much tied into the Unifi system for cameras, sensors, Wifi so did not ideally want to change and I'm sure I can live with this but realistically what are the options.
There is a baby jumbo frames hack you can do for PPPoE, I never had much luck with it but I think @RSR has.I was doing some monitoring via ssh and top and watching it hit 95% cpu use on downloads thanks to pppoe. I think it might be as I'm running protect with a decent amount of cams its just not got the cpu power. Will disable protect, Reboot and give it another try. The next step up if its not protect is a EFG and thats just silly for home use so option 1 or 3 will come into play.
I’m using an Orbi 970 direct to the ONT, no problem saturating a 2500/2500 connection.Are any of you using PPPoE with your own router ?
Are there any benefits to doing this apart from removing the double nat
Why does Unify not have hardware offload for PPPoE when every other bog standard router does?
Or is it just because Unifi are using slow processors? 1.5GHz isn’t great.
If you can get Aquiss to give you a routed /30 of IPv4 then you can terminate your PPPoE on a suitable box that does handle it well
my 18 months is up with Zen. Been a problem free experience throughout. Half tempted to get the 1800 down/900 up service this time round but I'm pretty sure my current network setup wouldn't make use of the additional speed, and changing it all would be a royal pain in the backside (and expensive).
