Cleaning with snow foam review
I find that the foam doesn't remove that much when washing for me but it does loosen the dirt quite well, a lot better than when I used to throw a few buckets of water over the car prior to washing. Usually foam/rinse/foam & wash with a mitt/rinse/dry, If I waxed & washed the car more often then the foam might do an OK job between proper washes but for the monthly wash and yearly wax it gets it doesn't really bring it up anywhere near clean enough.
Would like to try this out but machine mart still have my pressure washer after i returned it for springing a leak. They said it will take 10 days to get their engineer to have a look. They wouldn't even replace it there and then, or lend us one in the meantime, so a word of warning. Don't buy from machine mart. Buy from screwfix or argos instead.
You can certainly give it a try. I tried it with my power washer and it was pretty terrible. With a snow foam lance it worked wonders though.
Have to say having had snow foam lance for 1 year, not entirely sure it does anything to improve the quality of the wash, but it is good fun :D
