Hi Guys,
I have the following bits:
Asus P5K Mobo
Q6600 Processor Go Stepping
Gcube X1950Pro Card
4GB OCZ 800Mhz Ram
Arctic Cooler Freezer 7 Pro
So far the system has been clocked as follows:
CPU Ratio: 9
FSB Strap to north: 333Mhz
FSB Freq: 356
PCIE: 100
Dram Freq: DDR2-854Mhz
Dram Command Rate: Auto
Dram Timing Control: Manual
5-5-5-5-15
Ras to ras: Auto
Row Refresh: Auto
Write Recovery: Auto
Write to read: Auto
Read to Precharge Time: Auto
Dram Static Read: Auto
Transaction Booster: Disabled
Clock Over-Charging Mode: Auto
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Voltage: 1.4000V
CPU Voltage Ref: Auto
CPU Voltage Dampner: Disabled
CPU PLL Voltage: Auto
Dram Voltage: 2.2v
FSB Termination Voltage: Auto
North Bridge Voltage: Auto
North Bridge Voltage Ref: Auto
Advance.....
Cpu Ratio Control: 9
C1E Support: Disabled
Cpu TM Function: Disabled
Vanderpool Tech: Disabled
Ececute disable bit: Enabled
Max CPUID Value Limit: Disabled
Its running now at 3204Mhz.
Can it go higher, what do I need to change, increase or lower to get the maximum speed and performance wise.
Regards.
Asus P5K Mobo
Gcube X1950Pro Card
4GB OCZ 800Mhz Ram
CPU Ratio: 9
FSB Freq: 356
PCIE: 100
5-5-5-5-15
Ras to ras: Auto
Row Refresh: Auto
Write to read: Auto
Dram Voltage: 2.2v
Advance.....
Regards.
and I'll give your tips a go asap and report back.
