Cloning a drive.
15 Oct 2010
Afternoon all,
I'm about to upgrade my computer and I'm wanting to clone my Windows drive to a new drive, however as the SSD was too small I moved the downloads/documents etc (folders) onto my secondary drive, if I clone my windows drive will the presets that I have arranged also follow or will it corrupt them in some way?
Thanks in advance.
Should be fine, I have just done this with Clonezilla, went from OS drive 120gb ssd to 500gb ssd.
Had to clone the whole drive, then resize the partition to use the extra space.
One strange thing I had, I had to make the main partition smaller first(reduced it by 1 gb) then it recognised the rest of the space and I could resize the partition to full space.
Seems odd but I'll make sure to look out for it. Thanks for the heads-up.
5/5! Macrium is totally free, very easy to use, full of features, has an awesome pre-boot environment. Really can't fault it!
If you are using Samsung drives, their free data migration software works well. I cloned my Samsung Evo 850 250GB to a Evo 970 500GB without any issues.
Sadly I don't own any Samsung drives but thanks for the heads-up about it, definitely keep that in my for any future purchases :)
Yeh macrium just takes care of partition sizes automatically assuming the total data on the source drive is less than the size of the destination drive.
I used the EaseUS Todo Backup free version to move from a larger drive to a smaller drive the other day. Moving from a normal HDD to SSD for a neighbours laptop. As long as the SSD is larger than the space your using it worked fine. Didn't have to play with partitions or anything.
