Clutch gone in car, garage charging £700 !
18 Oct 2002
At home
Just found out my Nissan Alerma 2000 clutch is gone, not sure if that is 'common. Done about 70,000.
They want to charge me £700, inc vat and labour, seems crazy expensive. any advice ?
Thanks.
FWIW, I once took my car to get the gearbox swapped. I supplied the gearbox and they charged me £80 for labour.
Add about £100 for the clutch and another £20 labour and that's what I'd expect to pay.
£700 is pretty ridiculous.
While the gearbox was out which they charged £80 to swap.
The OP's gearbox isn't out though?
Edit: Oh I see now. :D £100 labour. Still seems quite cheap but I guess normal labour rates for a back street garage.
I didn't get the clutch changed, that was just an example :D I took it to a place that specifically dealt with transmissions.
You can swap a gearbox in a couple of hours if you have access to ramps and know what you're doing. Before we got rid of the unit, I helped a mate swap a box in about 3 hours using ramps... just drop it out the bottom.
Depends entirely on how much abuse it's had during those 70,000 miles.
£420 still sounds a little dear to me, I'd expect nearer £300 for a basic clutch change on a cheap car like that, unless there's some car-specific reason why it would take hours!
This. ^^
300 quid tops & make sure they fit a Decent plate & do the bearing.
Agreed, I would say £300-350 I would be aiming for, just out of interest how long did it take you to ring round and save nearly £300?.
Cheers, but yeah you're right.
Got it down to £420 now which seems better. Is it right for the car of my age for the clutch to go ?
Depends, did you let your misses drive it?
my golf's second clutch has been in for 80k miles and i kill it a lot. id have expected a clutch on a decent modern car to last well past 100k miles
id take the car elsewhere tbh
