Struggling to make out from the pictures, what were your max temps in Prime95 and Heaven?
The temps in the top pic look pretty high so I'm guessing they were with the old setup?
All looks good though. Getting temped by the RX240 rad, although might just get an external 1080 rad (or 2) if my noise & temps don't improve.
Looking good mate, nice job.
Though I dont really rate XSPC rads tbh, I had the RX480 and RS240, and I got better temps using my old Alphacool triple rad using the same fans. (the Alphacool rad was only 45mm thick as opposed to the 56mm thick RX series)
The new Thermochill TA series rads are much nicer imo.
I've tried the TFC quad X-Changer, XSPC TX480, and Thermochill PA and TA series, and the TA rad is by far the best out of them all.
I expected to see a dramatic drop in temps going from a dual and triple to a dual and quad (the XSPC RX480), but instead I ended up having worse temps, and a year down the line about 2 weeks after my warranty expired the RX rad developed a leak from one of the center tubes.
They are one of the most expensive quad rads out there, that's what made me buy the thing in the first place, but like I said it didn't perform as well as any of the other rads I have tested personally.
Also the finish on them is pretty poor as well, the paint was flaking off my RX480 when I bought it, and it only got worse as time went on, same with the Feser X-changer, but my Thermochill rads have a much durable finish on them imo.
I got a good deal on my RX480 I got it from OcUK for £60 as opposed to the prices they sell for now (I got it when they were selling off all the old WC stock), but after owning one there's no way I'd advise anybody to go out and spend £114 on the RX480 simply because of the issues I had, like I said, I expected to see a change in temps going from a triple and double to a quad and double, but instead I ended up with higher temps.
Thanks will have to add that to my list, as that would look good as well. Now even more confusedGreat build! What about a smoky/charcoal fininshed acrylic?
Thanks for the comments. I will be doing a bit of overclocking now i have a good cooling system. The CPU has already been pushed to its limit on aircooling, a 1090T running at 4.1GHz which i thought was a fairly good OC for that chip. Those Phenoms will never clock as high as the intel chips, but i use AMD as it is such a good allrounder and extremly good performance for the price. If you look at the bencmarks against the previous £900 i7's there is not that much between them.I think it looks much nicer than my build and I think you did the right thing getting the parts you did up front (EK CPU block and the 650 pump). I bought a cheaper kit and ended up replacing mine, making it more expensive in the end.
Few too many lights in it for me (I prefer my PCs to be dark in case I leave them on overnight) but I think it looks good. Also glad you managed to get a 240mm rad to fit in the bottom. there's not a lot of space once you have a PSU down there is there!?
Surprised you haven't overclocked the CPU a bit though. As it is your load temps are like my idle temps! (1055T @ 3.5GHz)
Mind you my chip/mobo does require quite a few volts when overclocking.
If my results turned out as good as yours I suspect I'd have been happier with mine.
Lets hope for both our sakes that DavyBoy's experience with the XSPC Rads was a one-off. If the bottom one leaked it would be bad enough, if the tops one leaked...
Thanks guys.very impressive, i hope i gain enough confidence to try watercooling at some point too![]()
