CM Stacker 830 or Silverstone TJ07?
23 Mar 2006
Guildford, Surrey
I'm getting a new case for my dual core/sli rig and im not sure what to invest in. I'm going watercooled for the cpu. It's between the CM stacker 830, and the silverstone tj07, and well, by the time ive got all the case fans for the stacker the cost will be the same. So with the issue of cost aside, which one will be best?
Ive seen so many pics of the TJ07, and you can see its one of those cases that in the flesh rox x10 the pictures... Get the SilverStone matey! :p
The TJ07 is built better, holds its value better if you came to sell it, looks better to my eyes aswell.
I would personally out of the two listed spend my money on the TJ07.
You my want to read up on the revisions of the TJ07, and maybe hold on for the new one to come through.
But I would take the Lian Li PC7+II over the TJ07 but thats a different matter.
oh yes i heard about those.. Have these been corrected as of yet or are they still pending?
Since I notice the new stock has just become available.
Can anyone recommend a good tower case for a watercooled system. I know the lian li's are good - are there any better than this case. Im mainly interested in airflow.
What size rad - as this is probably the biggest issue in choosing a case for watercooled setup.
ps If Carlsberg did comptuer cases... they would ask Lian Li to make em. ;)
They got purchased by Coolermaster and designed the ATCs cases, and the wavemaster.
Brilliant cases, but they cost a fortune and not enough profit in them, so some of the designers formed Silverstone. :)
But the build quality went, due to not wanting to go bust :p
The TJ07 cools better than the stacker 830.
So u used to design the cases?
Yewen said:
Would not go that far, neither make perfect ranges and both makers have issues.
I have quoted myself for truth. :p
If Carlsberg did comptuer cases... they would ask ATC-Tek to make them.
Oops - meant to quote this. :) Thought you may have worked for them, given your sig and all.
