Computer not detecting wireless network.
ok do this
try a new network cable
try it once like that
ping 192.168.1.1
open the browser and type 192.168.1.1
then start run cmd ipconfig /all
and once with the obtain an ip addy auto ticked
but make sure the firewall setting are disabled on that card
just wondering your network card is it NVIDIA nForce Networking Controlle and if it is did you install the firewall software that came with it if so uninstall it.
crashuk said:
start control panel network connections then click on the network card left click properties then it open s a new box then in the white box it should say " internet protocol (tcp/ip) " hilight that and press properties
a new box opens and select auto and apply
ip, dns, both? Didn'twe just do that?
ok go to your lan tcp/ip connect
make sure that ticked
then
do this start run cmd
then type ipconfig /release
then tyep ipconfig /renew
post what it says.
I got on the renew.
C:\Documents and Settings\Thomas>ipconfig /renew
Windows IP Configuration
No operation can be performed on Wireless Network Connection while it has its me
dia disconnected.
An error occurred while renewing interface Local Area Connection 5 : unable to c
ontact your DHCP server. Request has timed out.
Do you believe we are getting anywhere or just guessing our way through hoping something is going to change?
Does anyone actually suspect a certain problem?
ok do this start run cmd
now do this ipconfig /flushdns
ipconfig /release
ipconfig /renew
there 2 more options iam gonna do.
ok go back to the network cards tcp/ip setting and copy the following
the ping your router 192.168.1.1 start run cmd ping 192.168.1.1
The latter, from the looks of it. Constantly trying to get a new DHCP lease without doing anything else (or randomly pushing buttons) ain't going to fix anything.
From the looks of it, there's something screwed between your machine and router, since a) it should be getting an IP automatically or b) if you manually set the IPs, everything should work fine.
The multiple posting and nonsensical replies doesn't make it easy to keep track of what exactly you've tried and what doesn't work though.
well if his router is config according to the pics then his router is config correctly, if his card is configured with and with out ip, and we have flush dns and release and renewed ip now the last part if that dont work then it either the card.
the ip he is getting is either when he hasnt got a dhcp or there wasnt a dhcp and now there is, in in order for us to loss the appipa ip we needed to do the steps we did.
An error occurred while renewing interface Local Area Connection 5 : unable to contact your DHCP server. Request has timed out.
WIll try the alternate... now.
