- 30 Aug 2009
Please don't be ignorant.Maybe we are a wrong, and op is just an attention troll, and needs a perma ban
Could you please elaborate?I think it's an OSI layer 8 issue tbh.
Erm, the last 3 pages of it.Which advice please?
Sorry have been very preoccupied with issues left right centre.
I've heard of No Effort November, but this thread takes the biscuit. It sounds as though you just want a quick fix, but in reality it's not going to be that simple.
Create a USB stick with the latest BIOS (0703 at time of posting) on it. Create your Windows installation USB stick with another computer. Completely erase the OS drive. Reset and update your BIOS. Reinstall Windows.
The above is the cleanest way I can think of resetting absolutely everything. Using your USB stick in another computer removes the possibility of your current machine infecting the stick again. Erasing your OS drive before updating the BIOS should remove the somewhat unlikely possibility of anything malicious installed on your drive interfering with the BIOS flashing process. Then reinstalling Windows ensures you have a operating system you can have a high confidence in being clean.
If you reinstall Windows, why on earth would the above happen again? Disable Wi-Fi and bluetooth and anything else wireless if you want to remove the possibility of anybody outside your house sniffing wireless devices. I do think this is unlikely, however.
I have heard of wireless keyboards and mice doing their own thing. The cause usually turns out to be old hardware picking up interference from something else, such as somebody else's wireless device. I have also seen wireless mice behave quite randomly when the battery level is low.
I just want a resolution , if i reformat windows I am certain this fiasco will happen all over again.
...may i suggest at least running Malwarebytes AdwCleaner to get a report of anything suspicious on your system)
Personally i don't think it's anywhere near as sophisticated as a BT or UEFI hack, no offence to the OP but most 'hackers' simply wouldn't waste those sorts of resources on a nobody.
I suspect what's happened is the OP's installed some sort of remote desktop software (either intentional or unintentionally) and they saw whoever remoted in accept a BT pairing request followed by some other stuff and automatically assume it was BT related. Just checking what's installed through add - remove programs would probably show something like team viewer.
Thanks I will try this and get back to you. But it looks like a constant attack from some subhuman.I've heard of No Effort November, but this thread takes the biscuit. It sounds as though you just want a quick fix, but in reality it's not going to be that simple.
It's unlikely.Thanks I will try this and get back to you. But it looks like a constant attack from some subhuman.
Its true, not being paranoid but i have s***** nieghbours.It's unlikely.
Perhaps, but at least the information is there if they want to try it at a later point.Hate to disappoint you but you wasted a lot of time typing that out. OP will reply with some other random thing ignoring everything. Sound advice nonetheless.
1. Click Search on taskbar, type in "msinfo32" to find what BIOS version you are on now. If it is 0502 or older then you will need to download latest 0703. If you already on latest 0703 then you dont need to update BIOS.Well for starters I haven updated the Bios since i got the board.
The anti virus doesn't detect anything strange.
The usb stick is reappeared when going to disk management and sorting it out there.
You guys are obviously more knowledgable than me but we can't pinpoint this issue exactly, been very apprehensive about touching my setup again.
Display Name | Registry Name | Display Version | Registry Time | Install Date | Installed For | Install Location | Install Folder Created Time | Install Folder Modified Time | Install Folder Owner | Publisher | Uninstall String | Change Install String | Quiet Uninstall String | Comments | About URL | Update Info URL | Help Link | Install Source | Installer Name | Release Type | Display Icon Path | MSI Filename | Estimated Size | Attributes | Language | Parent Key Name | Registry Key |
3DMark | Steam App 223850 | 21/09/2022 14:58:19 | All Users (64-Bit) | D:\Program Files (x86)\Steam\steamapps\common\3DMark | 04/07/2016 07:47:36 | 03/11/2022 23:21:24 | DESKTOP-5DAA8IB\emsw0 | Futuremark | "D:\Program Files (x86)\Steam\steam.exe" steam://uninstall/223850 |
![]() 3DMark - The Gamer's BenchmarkBenchmark your PC, tablet and smartphone with 3DMark, The Gamer's Benchmark. Free download, start benchmarking today.
![]() Steam SupportLog in to your Steam account to get help with your Steam games, contact Steam Support, request refunds, and more. Help is also available if you can't log in, need to reset your password, or recover a hijacked account.
| D:\Program Files (x86)\Steam\steam\games\c0fa42ea207eb2224aad77958aef17d55c025a2d.ico | 3,399,416 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\Steam App 223850 | ||||||||||||
3DMark 11 | {f9e83b9c-ab7e-4005-8f32-4ea69703a5e4} | 1.0.132.0 | 21/09/2022 14:58:25 | All Users (32-Bit) | C:\ProgramData\Package Cache\{f9e83b9c-ab7e-4005-8f32-4ea69703a5e4} | 22/06/2016 22:12:18 | 17/01/2018 06:23:47 | BUILTIN\Administrators | Futuremark | "C:\ProgramData\Package Cache\{f9e83b9c-ab7e-4005-8f32-4ea69703a5e4}\setup.exe" /uninstall | "C:\ProgramData\Package Cache\{f9e83b9c-ab7e-4005-8f32-4ea69703a5e4}\setup.exe" /modify | "C:\ProgramData\Package Cache\{f9e83b9c-ab7e-4005-8f32-4ea69703a5e4}\setup.exe" /uninstall /quiet | www.3dmark.com | www.3dmark.com | www.3dmark.com | Windows Installer | C:\ProgramData\Package Cache\{f9e83b9c-ab7e-4005-8f32-4ea69703a5e4}\setup.exe | 236,993 KB | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{f9e83b9c-ab7e-4005-8f32-4ea69703a5e4} | ||||||||
Alien: Isolation | Steam App 214490 | 21/09/2022 14:58:19 | All Users (64-Bit) | D:\Program Files (x86)\Steam\steamapps\common\Alien Isolation | 04/07/2016 07:52:16 | 08/06/2020 06:25:12 | DESKTOP-5DAA8IB\emsw0 | Creative Assembly | "D:\Program Files (x86)\Steam\steam.exe" steam://uninstall/214490 |
| D:\Program Files (x86)\Steam\steam\games\23a83fe7c6034a9fbbd1b638a0ac15864b234002.ico | 31,584,300 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\Steam App 214490 | |||||||||||||
Amazon Games | {4DD10B06-78A4-4E6F-AA39-25E9C38FA568} | 2.1.5699.1 | 21/09/2022 14:55:55 | 25/11/2021 | emsw0 | C:\Users\emsw0\AppData\Local\Amazon Games\App | 22/07/2021 01:43:12 | 25/11/2021 01:57:39 | DESKTOP-5DAA8IB\emsw0 | Amazon.com Services, Inc. | "C:\Users\emsw0\AppData\Local\Amazon Games\App\Uninstall Amazon Games.exe" /X{4DD10B06-78A4-4E6F-AA39-25E9C38FA568} | "C:\Users\emsw0\AppData\Local\Amazon Games\App\Uninstall Amazon Games.exe" /X{4DD10B06-78A4-4E6F-AA39-25E9C38FA568} | msiexec.exe /x {4DD10B06-78A4-4E6F-AA39-25E9C38FA568} /qn | Amazon Games |
![]() Prime Gaming | Discover, download, and play gamesEnjoy games and more gaming extras every month with Amazon Prime.
| C:\Users\emsw0\AppData\Local\Amazon Games\App | Windows Installer | C:\Users\emsw0\AppData\Local\Amazon Games\App\Uninstall Amazon Games.exe | 461,824 KB | No Modify, No Repair | en-US | HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall\{4DD10B06-78A4-4E6F-AA39-25E9C38FA568} | |||
Amazon Kindle | Amazon Kindle | 1.26.0.55076 | 21/09/2022 14:55:54 | emsw0 | C:\Users\emsw0\AppData\Local\Amazon\Kindle\application | 07/12/2019 15:21:56 | 07/12/2019 15:21:57 | DESKTOP-5DAA8IB\emsw0 | Amazon | C:\Users\emsw0\AppData\Local\Amazon\Kindle\application\uninstall.exe | "C:\Users\emsw0\AppData\Local\Amazon\Kindle\application\uninstall.exe" /S | Nullsoft Install System | C:\Users\emsw0\AppData\Local\Amazon\Kindle\application\Kindle.exe | HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall\Amazon Kindle | |||||||||||||
AMD FreeSync(TM) Demo 0.9.1 | FreeSync_is1 | 21/09/2022 14:58:19 | 09/12/2018 | All Users (64-Bit) | D:\FreeSync | 09/12/2018 05:02:09 | 09/12/2018 05:02:09 | BUILTIN\Administrators | "D:\FreeSync\unins000.exe" | "D:\FreeSync\unins000.exe" /SILENT | Inno Setup | D:\FreeSync\bin\freesync.exe | 277,364 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\FreeSync_is1 | ||||||||||||
AnyToISO | AnyToISO_is1 | 3.9.6 | 21/09/2022 14:58:24 | 26/06/2020 | All Users (32-Bit) | D:\Program Files (x86)\AnyToISO | 26/06/2020 22:02:28 | 26/06/2020 22:02:30 | BUILTIN\Administrators | CrystalIDEA Software | "D:\Program Files (x86)\AnyToISO\unins000.exe" | "D:\Program Files (x86)\AnyToISO\unins000.exe" /SILENT |
AnyToISO - Open/Extract/Convert to ISO, Extract ISO, Make ISOFile Extract/Convert To ISO on Windows & macOS, CD/DVD/Blu-ray disk to ISO, Folder to ISO
![]() | Inno Setup | D:\Program Files (x86)\AnyToISO\anytoiso.exe | 5,608 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AnyToISO_is1 | |||||||
Apple Application Support (32-bit) | {FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E} | 4.3 | 21/09/2022 14:58:25 | 11/05/2016 | All Users (32-Bit) | C:\Program Files (x86)\Common Files\Apple\Apple Application Support | 11/05/2016 07:32:30 | 11/05/2016 07:32:31 | NT AUTHORITY\SYSTEM | Apple Inc. | MsiExec.exe /I{FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E} | MsiExec.exe /I{FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E} | msiexec.exe /x {FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E} /qn |
![]() Apple (United Kingdom)Discover the world of Apple and everything iPhone, iPad, Apple Watch, Mac and Apple TV, plus accessories, entertainment and expert device support.
www.apple.com
www.apple.com
Official Apple SupportFind out more about popular features and topics, and find resources that will help you with all of your Apple products.
www.apple.com
| C:\Users\emsw0\AppData\Local\Temp\is-63GGH.tmp\ | Windows Installer | C:\Windows\Installer\{FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E}\WinInstall.ico | C:\Windows\Installer\266f269.msi | 163,544 KB | Windows Installer | en-GB | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E} | |||
Apple Application Support (64-bit) | {2937FD88-C9D6-4B82-B539-37CD0A572F42} | 4.3 | 21/09/2022 14:58:19 | 11/05/2016 | All Users (64-Bit) | C:\Program Files\Common Files\Apple\Apple Application Support | 11/05/2016 07:32:34 | 11/05/2016 07:32:35 | NT AUTHORITY\SYSTEM | Apple Inc. | MsiExec.exe /I{2937FD88-C9D6-4B82-B539-37CD0A572F42} | MsiExec.exe /I{2937FD88-C9D6-4B82-B539-37CD0A572F42} | msiexec.exe /x {2937FD88-C9D6-4B82-B539-37CD0A572F42} /qn |
www.apple.com
www.apple.com
www.apple.com
| C:\Users\emsw0\AppData\Local\Temp\is-63GGH.tmp\ | Windows Installer | C:\Windows\Installer\{2937FD88-C9D6-4B82-B539-37CD0A572F42}\WinInstall.ico | C:\Windows\Installer\266f26f.msi | 182,190 KB | Windows Installer | en-GB | HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\{2937FD88-C9D6-4B82-B539-37CD0A572F42} | |||
Apple Mobile Device Support | {44325855-D4CA-4994-A27A-39FE50CE6A8E} | 16.0.0.30 | 30/10/2022 01:48:57 | 30/10/2022 | All Users (64-Bit) | C:\Program Files\Common Files\Apple\Mobile Device Support | 11/05/2016 07:32:39 | 30/10/2022 01:48:56 | NT AUTHORITY\SYSTEM | Apple Inc. | MsiExec.exe /I{44325855-D4CA-4994-A27A-39FE50CE6A8E} | MsiExec.exe /I{44325855-D4CA-4994-A27A-39FE50CE6A8E} | msiexec.exe /x {44325855-D4CA-4994-A27A-39FE50CE6A8E} /qn |
![]() AppleDiscover the innovative world of Apple and shop everything iPhone, iPad, Apple Watch, Mac, and Apple TV, plus explore accessories, entertainment, and expert device support.
www.apple.com
www.apple.com
Official Apple SupportLearn more about popular features and topics, and find resources that will help you with all of your Apple products.
www.apple.com
| C:\Users\emsw0\AppData\Local\Temp\iTunes64Setup.exe_232761667090897\ | Windows Installer | C:\WINDOWS\Installer\{44325855-D4CA-4994-A27A-39FE50CE6A8E}\Installer.ico | C:\WINDOWS\Installer\3a0314be.msi | 108,626 KB | Windows Installer | en-US | HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\{44325855-D4CA-4994-A27A-39FE50CE6A8E} | |||
Arc | {CED8E25B-122A-4E80-B612-7F99B93284B3} | 1.0.0.9668 | 21/09/2022 14:58:25 | 14/02/2016 | All Users (32-Bit) | C:\Program Files (x86)\Arc | 14/02/2016 09:37:30 | 15/02/2016 08:31:02 | BUILTIN\Administrators | Perfect World Entertainment | "C:\Program Files (x86)\InstallShield Installation Information\{CED8E25B-122A-4E80-B612-7F99B93284B3}\setup.exe" -runfromtemp -l0x0809 -removeonly | "C:\Program Files (x86)\InstallShield Installation Information\{CED8E25B-122A-4E80-B612-7F99B93284B3}\setup.exe" -runfromtemp -l0x0809 | msiexec.exe /x {CED8E25B-122A-4E80-B612-7F99B93284B3} /qn |
![]() Arc GamesThe official homepage of Arc Games, a video game publisher specializing in premium and free-to-play experiences for PC and consoles.
Access the Best Online Games | Arc GamesArc brings your favorite games, communities, media and entertainment together onto one easy-to-use platform.
![]() | D:\ArcInstall_STO_20151009a.exe | Windows Installer | C:\Program Files (x86)\Arc\images\logo_new.ico | 152,691,264 KB | No Modify, No Repair | en-GB | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{CED8E25B-122A-4E80-B612-7F99B93284B3} | |||||
ART-Mark version 0.76 | {E6EF6B79-D49F-4F5B-B3DE-04831310A09A}_is1 | 0.76 | 21/09/2022 14:58:25 | 25/04/2021 | All Users (32-Bit) | D:\Program Files (x86)\ART-Mark | 25/04/2021 09:37:31 | 25/04/2021 09:39:01 | BUILTIN\Administrators | Perschistence | "D:\Program Files (x86)\ART-Mark\unins000.exe" | "D:\Program Files (x86)\ART-Mark\unins000.exe" /SILENT | Inno Setup | D:\Program Files (x86)\ART-Mark\ART-Mark.exe | 2,722,483 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{E6EF6B79-D49F-4F5B-B3DE-04831310A09A}_is1 | ||||||||||
Auslogics Disk Defrag | {DF6A13C0-77DF-41FE-BD05-6D5201EB0CE7}_is1 | 10.0.0.3 | 21/09/2022 14:58:25 | 03/02/2021 | All Users (32-Bit) | D:\Program Files (x86)\Auslogics\Disk Defrag | 03/02/2021 22:55:59 | 03/02/2021 23:34:37 | BUILTIN\Administrators | Auslogics Labs Pty Ltd | "D:\Program Files (x86)\Auslogics\Disk Defrag\unins000.exe" | "D:\Program Files (x86)\Auslogics\Disk Defrag\unins000.exe" /SILENT |
Contact AuslogicsFind news, press releases and all the information you may need to prepare media coverage about the company and our products.
www.auslogics.com
Get New Auslogics Disk Defrag Version and Defragment Hard DriveWondering how to defragment files and help hard drive run more efficiently? Update your Auslogics Disk Defrag to the latest version & speed up your HDD.
www.auslogics.com
Auslogics Support CenterWelcome to Auslogics Technical Support! Having installation problems? Have a question about how to use the product? You will find various resources where you can find help below.
www.auslogics.com
| Inno Setup | D:\Program Files (x86)\Auslogics\Disk Defrag\Integrator.exe | 57,875 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{DF6A13C0-77DF-41FE-BD05-6D5201EB0CE7}_is1 | |||||||
AviSynth+ 0.1.0 r2508 | {AC78780F-BACA-4805-8D4F-AE1B52B7E7D3}_is1 | 0.1.0.2508 | 21/09/2022 14:58:25 | 10/08/2017 | All Users (32-Bit) | D:\Program Files\AviSynth+ | 10/08/2017 06:36:43 | 10/08/2017 06:36:52 | BUILTIN\Administrators | The Public | "D:\Program Files\AviSynth+\unins000.exe" | "D:\Program Files\AviSynth+\unins000.exe" /SILENT |
Releases · AviSynth/AviSynthPlusAviSynth with improvements. Contribute to AviSynth/AviSynthPlus development by creating an account on GitHub.
| Inno Setup | ..\Icons\Ico\InstIcon.ico | 6,726 KB | No Modify, No Repair | HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{AC78780F-BACA-4805-8D4F-AE1B52B7E7D3}_is1 |
Purchasing a Windows USB disk seems like a waste of money, you could have created this for free.Its true, not being paranoid but i have s***** nieghbours.
Also I have a purchased windows 11 pro usb stick but now when i press f8 iy doesn't appear in the boot list?
WOW.... REALLY...Please don't be ignorant.
Update BIOS to the latest available for your board and reset all settings. Create new Windows 11 install media using the media creation tool, and start from scratch.
If there's no antennas plugged in, your wi-fi/BT range will be awful. The likelihood of your master hacker neighbours being able to connect to your computer through multiple walls is basically nil.
Updating the BIOS and reinstalling Windows seems a bit extreme IMO, especially when (as i suspect) all he'd need to do is look through his add - remove program list for anything he doesn't recognise as something he installed or better yet just do what AthlonXP1800 suggested and post the list of what's installed.Purchasing a Windows USB disk seems like a waste of money, you could have created this for free.
And while he's at it running Malwarebytes AdwCleaner to get a report of any suspicious malware.
I am. However that requires a level of sophistication that most people simply wouldn't bother with, at least not some guy next door or your average support call scam.You realise applications can be hidden from the add remove programs list, right?
Are you also aware applications can also be hidden from all scanners?
