That might be so (we are yet to see) but wouldn't fit the point of this thread - CoolIT ECO vs Corsair H50.But the Eco 240mm will p0wn all!
Well, I'll just be happy if it handily beats Asetek's LCLC 240mm.
Barrolde, can you guys do some internal benches on that?
The reason for that was because at the time, everyone believed having the fan as the exhaust would be ideal so I didn't bother checking to see how it would perform with the fan as the intake. Afterall, this was the default configuration as marketed by CoolIT. It was also to do with the fact that people wanted to know how changing the fan to an exhaust on the H50 would impact performance. In hindsight, I should have done the intake tests on the ECO as well and may do so if I get the time.
They were pretty much the same, same fin spacing etc. And they both look very much the same so as you say, the pump could be more efficient.
The way I have the first graph is that I have the latest cooler tested at the top and then have a cleaner chart showing it in ascending order. I omit out the idle temps because it just makes them a lot messier and the load temperatures are what we are really interested in.![]()
Yeah for completeness sake it would be good if you could, but I understand if you don't have time.
It seems the H50 beats the Eco in many reviews but only by a degree or two. This means they both have their place; one is cheaper but marginally worse (so overall you get decent performance for your money)
For sheer performance, however, the H50 just about steals it
But when the prices are the same (as can be found elsewhere), it is in the best interests of those purchasing to get the best they can for their money. In this case, the better of the two as what separates them normally, doesnt in this example.
There are actually about the same amount of reviews that have us ahead by a degree or two as there are that have h50 ahead. In fact, if you look at very last graph of the Vortez review you will see ECO stock (exhaust) vs H50 exhaust where we are in fact ahead a degree.
I've updated the results with the intake fan configuration:
http://www.vortez.co.uk/contentteller/articles_pages/corsair_h50_cpu_cooler_review,10.html
Those new findings are fascinating,
I thought the clear margin would more-or-less remain, instead it seems the Eco does slight better, the plot thickens!
Still, I think those who are inclined to go beyond stock config. would prefer exhaust + decent fans.
So in that regard the H50 is likely to be more appealing...
these enclosed watercooling systems are CRAP simple as i dont know why we get such large threads on them.....
