** Corsair Carbide 540 High Airflow ATX Cube Case - NEW COLOURS **
  • Thread starter Thread starter rjk
  • Start date Start date
You have asked a question that only you can answer :confused:
How so? I'd have not asked it if I could answer it.
Is this an improvement over the coolermaster cosmos s? Ever since buying it I've been wishing I hadn't bought it, I initially didn't like it when I saw it 'in the flash' at a multiplay i-series event(can't remember the 'number') but for whatever reason I ended up buying it for my first water cooling build(the Silverstone that everyone and his dog used back then was too much).
from the information ive seen,
• Dual 3.5” hot swap bays
• Four 2.5” tool-free SSD drive cages
no 5.25 bays ?
and the thing that concerns me more is the lack of 3.5 bays, guess i would have to buy something external to hold my data.
no 5.25 bays ?
I can have a dvd drive in the case right? I need a DVD player in my case. otherwise I'll have to cancel my order.
This case and the raven are very different. Only you will know which has the features that suits your requirements.
Especially as your initial question was 'this or that'
Had you given a list of requirements or pointed out what features were most important to you then I am sure another member would have gladly helped with your case decision.
My opinion on the matter is that the Corsair will be the better WC case as the out of box rad support is better.
Anything after that is entirely down to personal taste imho
There are optical bays. Not sure why they aren't on the description. Will add when I get to work.
I got confused because I didn't see it in the info, but did see it on the pic. Thanks rjkoneill:)
Also I think I'll need a new dvd drive as mine doesn't have a dvd grip. The one I have now just lays on top of the door, but if I put it sideways the dvd would fall on the floor. So I think I need a slip in dvd drive like the PS3 original slim has.
Can someone point me to 5.25 DVD drive that can go vertical.
Cheers
