You can use any dvd drive in a vertical position as far as i know.
But not all 5.25" DVD drives have clips on the tray to hold the disk when it's vertical and the tray is opened.
Without those you can imagine how the disk will fall out when you open the drive vertically mounted.
All slim drives with a tray have a clippy thing on the spindle which holds the disk.
Exactly.
I would have to use a 5.25 holder. I would rather get a 5.25 dvd drive that can hold the disc. I'll ask again. Do OCUK sell these?
http://www.overclockers.co.uk/showproduct.php?prodid=CD-096-LO&groupid=701&catid=10&subcat=951
http://www.overclockers.co.uk/showproduct.php?prodid=CD-090-LG&groupid=701&catid=10&subcat=951
They all have the clips (Look at the right hand side), all you need to do is have a look it's not that hard.
This case and the raven are very different. Only you will know which has the features that suits your requirements.
Especially as your initial question was 'this or that'
Had you given a list of requirements or pointed out what features were most important to you then I am sure another member would have gladly helped with your case decision.
My opinion on the matter is that the Corsair will be the better WC case as the out of box rad support is better.
Anything after that is entirely down to personal taste imho
This case is confusing. I can't see it being great for air cooling as there's very few fans in the main area where the hot components are. But It also appears this case won't work to well with watercooling if the biggest radiator it will accept is a 2x 140mm? Which is a shame as I like the look of this case.
If you say so....The cooling in this case will be amazing.
If you say so....I have my reservations. Side fans are great at cooling heavily overclocked motherboards but to be honest I don't think this is aimed at high end air cooling and more mild overclocked systems with great looks.
On the watercooling front which I'm personally more interested in this sucks unfortunately. Who wants to have lots of 140mm radiators? It's much easier/cheaper and more efficient having nice big radiators. Looking at that video the radiator in the front looks terrible and covering a third of the motherboard up?
Sorry if thinking out loud and asking questions offends you RetrogamerX. Confusion over I guess.
I will personally wait for something with a better layout in the rear compartment to take bigger radiators. This case could look awesome and will look forward to seeing some builds in it.
