If you have positive pressure in the case you won't need to use any filters at all (except on the fan intakes) as air will be moving out of the case. Dust will never be a problem if you follow this golden rule.WHat is everyone using to filter the bottom vents? I'm finding dust starting to build up around there. I don't want to have to buy the Dmcflex filter set as its like £80. All i want is to filter this particular vent.
I know it's obvious but I'll say it anyway, positive pressure is achieved by having more fans blowing into the case than out.
Hi Matt,
The 540 Air Demciflex filter for the bottom is 148 x 313mm.
So this "should" work:
YOUR BASKET
1 x Silverstone SST-FF142B Magnetic Fan Filter - 320x155mm £5.99
Total : £8.96 (includes shipping : £2.48).
Anyone tried this able to feed back?
Found this thread where someone attached it successfully:
http://www.sweclockers.com/forum/14...ir-540-dark-bygglogg/index7.html#post14163242
8th pic down in that post.
Top banana, thanks danny!
What temperature are those 2 HDD's in the back sitting at?
38c and 40c still very cool tbh.
I installed 2 cheap 80mm fans on the rear and it brought temps down to mid 20's. Cost £10 for the fans and grilles.
I'd have this case for sure if they put 3.5" bay above the 2.5" ssd rack there, the lack of 3.5" support with a case of such size is what is disappointing for me. Looks like a really good case.
