10 min later, you mean like this?
Yes.
The pipes on the radiator can be which ever way suits your case,it's the pipes attached to the pump that work better at the top (When it's mounted to your cpu the corsair logo should be up side down).
Bobby, can't you have the rad mounted like it is in this picture:
But still have the block fitted like it is in this picture:
So then you will be able to fit your side panel without any issues.
What is it that is stopping you getting the panel on anyway, is it the side fan on the panel?
Anybody know what size & thread the fan screws are? as i need some longer ones to attach 2 x 120mm x 38mm fans.
cant find receipt with info on it, but sure there
What comes in h50 box "4 x Number 6 1.25" Pan Head self tappers"
Don't suppose anyone is planning to use one in a Lian Li V350/1?
