had my h50 since last july... my temps on an i7 920 have been as follows
3.8ghz >>> @ 19x201 (65-71c) push/pull apaches (idls @ 35-40c)
(mx2 paste) (bios : 1.25v) & (load : 1.21v)
4.0ghz >>> @ 20x200 (74-80c) push/pull apaches (idls @ 38-45c)
(mx2 paste) (bios : 1.33v) & (load : 1.26v)
i consider mine as average compared to some with cherry picked i7 cpus getting mid 60-75c @ 4.0ghz but you have to remember all the cpus are different internally so some need more voltage and some less (being better) and same goes for memory controller buit in some find it hard to run 2000 ddr3 without major upping of vdimm and vtt settings and some can work @1.5 with low vtt as is the case with mose 975 cpus.
at the minute best quiet High static pressure fans for the h50 are :
Static pressure 2.60
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM which 2 of these can be connected via a
Akasa AK-CB002 PWM Fan Splitter Cable
which can be connected to the 4pin fan header on most boards for pushpull.
Static pressure 5.90
120mm Scythe Gentle Typhoon 1850 rpm Cooling Fan 3-pin <<<<<<<<<<<<<<<
just bought 2 to try out see if better than my apaches
Static pressure 4.70
120mm Scythe Gentle Typhoon 1450 rpm Cooling Fan 3-pin
both of these in pairs can be connected via a
Akasa 3 Pin Fan cable splitter and then connected again to the cpu or spare sys fan header ...but note that some motherboards have not got the feature of changing voltages on fans to reduce speeds so with some boards that use a 3-pin on a pwm fan header the fans will be on full constantly.. so grab a fan controller
others like the enemax..Noctua..Noiseblocker ar just considered as case fans due to static pressure being around the 1.0 mark some less.
Scythe Ultra Kaze 2000RPM/3000RPM are
above 8.0 static pressure but is noisy unless speed reduced....but downside reduces static pressure by doing so.
120mm Delta Case Fan Focussed Flow fans are
above 20.0 static pressure
but very noisy at 4000RPM BUT dont think about connecting 2 of those beasts to a motherboard without a fire extinquisher nearby
i recommend connecting the pump to the PSU via a spare molex for full 12v power then you can be safe knowing it getting the correct requirments.
for this use a
Akasa 3-Pin to 4-Pin Adapter Cable
also remember you can always place the h50 in a 120mm ceiling fan position exhausting out the roof of the case if you find it easier as it doesnt matter what position the h50 is in to work>>>vertical...horizontal and same for pump writing facing up or down all the same.
Rhino"
