Man of Honour
After three hours of running the H50, the corsair fan in the Antec 183 still sounded awful. It’s now been changed for an Apache Black and the sound is now normal.
@HornyRhino
I thought the H50 would let you cut down on fans a bit, but surely mounting with push pull and all those case fans you may as well use a decent (and cheaper) air cooler.
I'm always looking to use as few fans as possible with my air setup whilst maintaining good airflow.
nice, any differents in temps? that copper one im looking at looks to be really nice.
now if some nice person here can help me fig out the 100% fan speed prob id be a happy lil lad
id say its made a little difference, to be honest for the hassle etc, id leave it as it is.
Another thing is, you will have a lot of air if you add a radiator, without a reservoir
Think the pump could handle a gpu block too? I know the performance wouldnt be great but im after silence rather than ultimate cooling, also is it 3/8" tubing used?
My finished mod on my H50
Modded Corsair H50-1 120mm rad with push/pull config fans are 2x coolermaster 120x120x25mm 1200 rpm 17dBa mounted as intake at rear,240mm all copper rad (make unknow) 2x coolermaster 120x120x25mm 1200 rpm 17dBa mounted at top of case intake,bottom fan coolermaster 120x120x25 1200 rpm 17dBa exhaust.
http://img532.imageshack.us/img532/3439/dscf0096o.jpg
