Not really, my fan's are too loud to hear it probably..
Anyone else with an H50 that causes really annoying buzzing noises? I only notice it after about 2 hours of use. It isn't noisy when I switch pc on. After a while a terrible noise starts. I really couldn't live with the racket. Anyone else have this on their h50?
HiAnyone else with an H50 that causes really annoying buzzing noises? I only notice it after about 2 hours of use. It isn't noisy when I switch pc on. After a while a terrible noise starts. I really couldn't live with the racket. Anyone else have this on their h50?
Hi
My H50 developed a buzzing noise about two weeks after I purchased it
Very enoying because I loved it for its quietness.
I contacted Corsair and they replaced it in under 2 weeks .
Very impressed.
Havn't put it in because I am keeping it for my new build .
Off the topic you are talking about guys:
I am just curious, if i should put 2 fans on my H50 Radiator? is there any benefits of doing this ? and if yes how should i set up the fans ? 1 blowing cold air from outside into the radiator and 1 blowing out of the radiator on the other side or ?
yes, but if you have your fans like this < Radiator < basicaly the inside fan will be blowing the hot air from inside the system onto the radiator and the other fan will be taking this hot air from the radiator outside the case.. but there wont be any Cold air blowing from outside into the radiotr or i miss understood you
Anyone got one of these in an Antec 300 case?
I'm assuming there is plenty of room for it with good air flow too?
EDIT: Nevermind there's a few in the case forums, so I'm good to go
think Balb0wa pics above are a antec 300?
