Here's my revised setup:
It used to be a push/pull exhaust and the temps were OK but at 100% load got to 70C and that was at stock 2.8GHz (Q9550).
I have now moved it to the drive bay area with the aid of zip ties. Same push/pull Enermax clusters on the rad and I now have a Lian Li additional fan bay with an Akasa Apache pulling air in to it.
Now the temps are like so:
About 40 idle and 55 full load. This is after the computer has been on a while and the room has warmed up. Can be as low as 30 idle when first switched on. Considering this room is very small, there's two people, two dogs, two computers and mines close to a radiator I'm quite happy with the temps. I'm also running at 3.4HGz now.
I could onl do better if I added higher CFM fans but the noise is just about right for me now. I'd only consider moving to a full custom loop if I wanted more performance.
