** CORSAIR LIQUID COOLING SOLUTIONS - CRAZIEST DEAL OF 2013 **
Are leaks prone from the pump, radiator or anyway along the tubing?
I've been using a H50 for the last 18 months but just bought a H80
I have had 2 leak (used ones that had been in service for years and swapped into many different computers, so above average usage) and the place they most commonly leak in my experience is where the tube comes from the radiator, people bend it very hard (especially in cases like the prodigy), and after installing it in many machines the wear and tear causes the barb to poke through the plastic tubing.
Can anyone tell me if i can fit the H100 in a Xion Predator 970? I would rather get the H100 over the H80 since its only £5 difference. But im not sure if it would fit.
So these water coolers should work for years and years if you don't bend them hard, I'm I right on that?
Preordered the H100. Such a cheap price, better than purchasing a brand new kit for a used system. My current system's running a Corsair A50 and mild OC to 3.3 from 2.8 on a 1055t. My case is stupid, it doesn't have a mounting for Radiator, so going to have to mod the sidepanel to fit it on... need to wait till it arrives though, so i can get the holes in the right place. Good price for such a good high quality cooling solution tbh.
