Cosmic DE
I see Fedora 42 has a Cosmic spin now, which is surprising considering how new Cosmic is. Anyone tried it?
Not the new spin, but I've been running cosmic installed on the standard gnome fedora 41 (now 42) for over two months now and I'm happy with it. Fedora just updated to alpha 7 so we'll see if it's fixed the minor issues I had. The bluetooth widget hasn't failed since that one time it did, will let the battery drain soon and see if it notifies on low battery, the file explorer searches upon typing now which is great and was the only real usability niggle I had relative to nautilus (prior version you had to click the magnifying glass first). My use case is heavily minimalist so YMMV, but the experience has been near-flawless.
I’m planning a fresh install soon so I’ll give it a try. I’m using a very vanilla Fedora 41 Gnome install at the moment but with Dolphin file manager installed as Gnome Files isn’t great.
Let the battery drain and it didn't notify, in fact there have been no notifications at all for a while I just didn't notice. It could be a consequence of installing cosmic over gnome (notification server still hooked into gnome somehow?). I can get a notification if I intentionally crash the cosmic-screenshot program (by cancelling mid-interactive execution without saving a screenshot, for whatever reason it panics on exit in that case), also using the tool notify-send to generate my own notification works.
notify-send working seems to rule out a bad notification server setup (according to this https://wiki.archlinux.org/title/Desktop_notifications ). So I'm not sure what's going on. Regardless, notifications might be iffy. If you try the spin it'll be interesting to see how notifications behave there.
I like the look of it but I'm not sure I'll jump from KDE just yet. I may wait for it to stabilise a bit first before trying it out.
I'm still on cosmic on standard fedora and recently switched to beta. I haven't had many issues, and TBH the muscle memory has kicked in so maybe I'm forgetting something.
What has been fixed: Opening a video now properly focuses so keyboard shortcuts work, in alpha I had to do win+shift+arrow to move the window before it focused to the point that they worked. The file manager now appears to handle sshfs mounts where before I resorted to nautilus. The file manager also now handles a fileshare USB mount with my android phone, before I resorted to nautilus.
Still buggy: When you scroll the file manager below the files on screen, the focused file is one too low so you can't see it and have to go one past then back up.
New issue: The titlebar of a video is now multiline if the filename is large enough, which does not fit the bar
Anything not mentioned "just works" I guess, YMMV. It's snappy and low memory footprint and hasn't crashed, and while I'm not using tiling as such there's keyboard shortcuts to snap windows to quarter/half/full locations which is good enough for me.
Is anyone still using this? I see popOS have now made it their default desktop so I assume it is reasonable stable now. If there are any users here how do you think it compares to the other major desktops and what advantages do you find?
Still using it and won't be looking elsewhere, it's ideal for someone like me who is happy with any DE that gets the basics right and doesn't care about customisation. It gets out of the way and is clean and performant. Can't speak to customisation other than it's allowed me to minimise dressing space to maximise application space, and I've disabled unnecessary things like the system dock in favour of using a few keyboard shortcuts to open my main programs.
That has been fixed now.
Thanks for the reply. You sound similar to me wrt what I am looking for in a de. I am currently using Plasma but changing the wallpaper and making the panel central similar to win11 is the only customisation I have done.
Perhaps I will have to install a cosmic distro in a vm and have a look when I get some time.
I thought the aesthetic was pretty similar to Gnome from what I saw but I haven't tried it yet. I don't mind Gnome. I have been back on KDE for a few years now but before that I used Gnome for many years after moving to it when the launch of KDE4 was such a disaster.
I'm tempted to try it again on my laptop. It's currently running Fedora 43 (Gnome) which honestly I struggle with - but I really like the touchpad gestures compared to KDE. Could just stick PopOS on for a go I suppose.
I've been using Cosmic primarily whilst I play around with Cachy. Seems quick and repsonsive enough.
One major issue is I cannot mount my network drives using Cosmic files but they worked straight out the box when using Plasma. There is probably something I need to run in the terminal but have not quite been bothered to look it up yet.
Please that they have roadmaps for Epoch 2 and 3 over the next year and a bit though.
Was testing out Cosmic for a bit but also went back to KDE. It looks promising but it's missing a lot of things in other desktop environments; at least some of them are planned for the epoch 2 and 3 updates.
For anyone with a touchscreen, it's a bit buggy to use with it. Example, tapping on a text field then trying to enter text with a keyboard doesn't always work, but selecting the same field with a mouse does. Some of the cosmic apps also don't do things like touch scrolling either, meaning you have to drag the scroll bar.
This is my view on it right now. The only real reason I was looking at Cosmic was because KDE was becoming less supported by companies/devs vs Gnome. But there seems to be a bit of a swing towards KDE in recent months (probably because Valve are backing it) so I'm less interested in alternatives. I'll still keep an eye on Cosmic though.
Cosmic will likely overtake KDE but it's not there yet, maybe in 1-2 years. My issues were Chrome doesn't go into dark mode, windows snapping not really working yet, need to change mouse settings in config files as many thing missing in the settings, various other issues.
I will be checking out future updates though.
