CPU ADVICE
Its not about that ... i was deciding or get 9800X3D if in multithread perform same as 9900X, but i saw on reddit many people asked gigabyte if rev 1.3 support 9000 series and its say its not supported , only rev 1.5 ..... but bios i installed and its is agesa 1202 ... latest... but i dont know if really work .... if i buy 9800X3D for ex and not working with mobo ... not found a proof if working or not ...
Can’t hurt to try, if BIOS has been updated. Can always switch back to the 7700 if it won’t boot.
Wait for official BIOS support, if unsure.
another question ... when a install a game my temp goes 85-86... when i play FC 25 my temps its 75+...... with PBO , curve optimizer -30 all cores.... ? high temps ?
Depends on instructions it's doing
If you worried about temps run cinebench single and multi and compare with what others are getting with the same CPU
Ryzen 7700
Max. Operating Temperature (Tjmax)
95°C
You can always set a temperature limit to 80 /85 in the BIOS if you are worried. Won’t affect performance very much.
What think about this case ?
This case with a arctic liquid freezer 3 420 good combo ?
good reviews and a huge case , but cases are a personal touch so just go with one you like the look of with half decent reviews
No and you really shouldnt be needing to replace Dark Rock Pro 5, only 280/360/420 but would the difference me worth while thats for you to decide
