- 6 Jan 2013
- Rollergirl
And because most developers would focus on console first
Why would they do that?
It is a known issue with this game using ryzen and nvidia. When used with a radeon card the difference is negligible. There is quite a comprehensive video about this on YouTube.
The point of these screens were to show CPU usage and how this will become an issue in the future. Not to show FPS differences.
It shouldnt be used as a example if it has a issue , to lose so many fps and to have such low gpu usage as in the example then its not a fair comparison of CPU usage either . If a radeon card shows no difference then thats what your example should have used.
Overall we cant look at cpu usage only you have to look at the overall picture which in that case looks like the Ryzen is miles behind the intel with current games in Gameplay FPS wise (which for most games it isnt).
Have to ask yourself if most people were looking at a review and one cpu gave you 60+ fps less in a game how many would think well the cpu usage is lower so its better vs how many would think well same gpu 60fps slower that cpu cant feed that gpu well i'll skip it.
Ryzen so far overall is a great platform and has brought much needed competition to the cpu market but images like that one do it more harm than good IMO
The first image was fine and a great way to show ryzens power![]()
That doesn't sound so convincing, based on so many reviews I just checkedAgreed not the best screenshot to use. My eyes wasn't on the FPS but CPU usage. Ironically when tested at 4k ryzen overtakes kabylake even with a 1ghz disadvantage.
Tomb raider is just one example, there are tons out there, division, mass effect etc.
That doesn't sound so convincing, based on so many reviews I just checked![]()
my sister now has my i7 920 - One of my favourite chips!I'm still rocking a i7 920. Looking at upgrading because the MB and poss Memory is on its way out. Only just swapped my 8800GTX for a 1070..Thats how often I upgrade...lol
The last AdoredTV video showed a pretty standard suite of games being used by one of the big sites (Tom's Hardware maybe) and when listed in order of release date, the newer ones universally favoured R7 over i7 (I think it was 4 out of the newest 5 had higher average FPS on Ryzen compared to Kaby Lake, and that's not even taking into account minimums or frame times, etc.This more cores patter is pure conjecture. It relies on the premise that future games will be coded for more than four cores. Core speed and IPC are still the king for gaming systems as far as I can see.
I would also consider 3-5 years as decent longevity.
Stop being coy
If gavinh87 won't spit it out, I will. Almost certainly if you are building a new rig right now then yes AMD Ryzen is the route to go. Bang for buck, Ryzen is much better than intel right now.
Would i swap to ryzen now whilst i have a 6700k? no not right now because im currently getting an equal experience in everything i use my system for. When my experience starts to be degraded by my cpu then i will upgrade but likely by this time another wave of cpus will be out.
It still takes several years to get good GPUs to easily handle 4k. By then it would be easy to purchase 32C64T CPUs at cheap price. 8C16T in 2017 would most likely waste their best years due to lack of good 4-way SLI with Pascal/Volta.+1
This is why I see my current 6700k lasting 3-5 years, and when it comes to replacing it I don't think it's going to be a current Ryzen that I'll go for. The current CPU arms race will dictate its replacement and I have no preference whether it be Intel or AMD.
Rise of the Tomb Raider is a really really bad example of Ryzen performance as 99% of reviews with that game are done on nVidia GPU's and certainly on Ryzen with the DX12 API nVidia's performance is shocking compared with AMD's GPU's.
For some reason nVidia's performance with DX12 is almost always slower than DX11 anyway, something is wrong with nVidia's DX12 drivers.
with the new intel 6 cores in august and x299 coming.id be waiting especially if you already own a decent cpu/rig.amd will also probably offer the next revision of whats out now which will probably clock better by a small amount and run cooler.its only a few months aswell.when you building a system thats going to last 5 years you might aswell get the best you can.
while ryzen offers value its not that great in reality over anything already out.the next intel stuff could be quite a lot faster.
Two "good" reasons for that.If you look at how well old Intel systems have lasted over the last 5 years, I wouldn't be overly concerned by my cpu choice.
Fast 4 cores will likely still do the job in gaming for a long time to come.
