- 17 Aug 2003
- Woburn Sand Dunes
i got a silver suprano without a window
forgive the mess lol
S-H-A-N-E said:
S-H-A-N-E said:Just put 1 more extra 120mm fan , temps from
CPU Temp = 38
M/Board Temp = 40
now
CPU Temp = 38
M/Board Temp = 31
turbotoaster said:thats more like it, what temp monitor are you using and have you got cpu-z as i want to know what voltage the chip is running
S-H-A-N-E said:Had a look on cpu-z , the voltage is between 1.37-1.408 , is this ok ?
The temp monitor i am running is EVEREST (The 30 day version)
i also think the problem is i have a very small mesh atx case with not a lot of room for air to flow , i just manage to squeeze my Arctic Cooling Freezer 64 Pro CPU Cooler and i will replace it with a Thermaltake bigger case , i stuck another 120mm fan inside which has dropped the motherboard temp down to 29-30, the cpu temp is still at 38 , what i am finding is that on the motherboard is a small chip fan that gets very warmLadforce said:you need a very thin covering of it. however, it takes a good few days before its fully set and your temps should fall a bit in that time.
